Bridgeport ATC Success ,.. but some Install Questi
- sspeed33317
16 Sep 2014 04:29 #51207
by sspeed33317
Replied by sspeed33317 on topic Bridgeport ATC Success ,.. but some Install Questi
Thank You,
I haven't done too much work on the HAAS lately , just a few wires and it should be a functioning 3 axis mill.
Just got a little discouraged with the tool changer, so I hope somehow studying what you have done will help
me get mine working.
Been thinking about building and adapting a twin arm changer to it instead, but that is another project all together.
- tkamsker
- Thank you received: 5
16 Sep 2014 15:54 #51231
by tkamsker
Replied by tkamsker on topic Bridgeport ATC Success ,.. but some Install Questi
when i can help let me know
Twin arm changer Does it mean you stay with Z axis in save position
An there is an arm which does the movement ?
Then you may like to read www.wallacecompany.com/machine_shop/Shizuoka/
where i got a lot of inspiration and part of my work is derived from that solution.
You save a lot of trouble if you don't have to move the Z axis
thomas
thomas
- ArcEye
- Thank you received: 758
16 Sep 2014 16:11 - 16 Sep 2014 16:12 #51234
by ArcEye
The other toolchanger that may be of interest is the Triac one I wrote for cncbasher
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...oolchanger_component
That has 2 pneumatic rams which move the carousel out to below the spindle and then up and down to do the tool change
The spindle stays in the same place throughout
It is simple to implement, because each ram had a switch at either end of the travel, just requires waiting until it is fully
extended or fully retracted before doing next bit.
Replied by ArcEye on topic Bridgeport ATC Success ,.. but some Install Questi
Been thinking about building and adapting a twin arm changer to it instead...
Last edit: 16 Sep 2014 16:12 by ArcEye.
- sspeed33317
17 Sep 2014 00:26 #51242
by sspeed33317
Exactly , the Z axis goes to tool change position and that's it.
I found some really neat Cam box type changers that handle the tool change in one rotation.
Even has a output shaft where you can mount switches to take care of the other operations, like tool release and clamp.
But they are very expensive.
The only thing that may be complicated is indexing the tool magazine.
I put a bid on a surplus twin arm unit, if I don't win it I may just rework what I have and make the carousel rise and fall. like the Triac.
But I am going to try to make what I have work also as it is.
You save a lot of trouble if you don't have to move the Z axis-
thomas
- ArcEye
29 Oct 2014 17:04 - 29 Oct 2014 23:54 #52522
by ArcEye
Thomas is now happy that pretty much everything is resolved with the config.
The Contributed Components wiki now has an entry with all web references and the full config zip
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...er_and_configuration
PS the URL has changed slightly
Now www.tkamsker.at/web/pub/bridgeport-412-retrofit
Last edit: 29 Oct 2014 23:54 by ArcEye.
Time to create page: 0.223 seconds
