Changing base/servo thread for 10kHz charge pump
- olesk
27 Aug 2014 00:24 - 27 Aug 2014 01:35 #50325
by olesk
Changing base/servo thread for 10kHz charge pump was created by olesk
I have a Leadshine MX3660 stepper controller that needs a 10KHz signal for the charge pump.
My current setting for BASE_PERIOD is 100'000 and SERVO_PERIOD 1'000'000 which I have no idea if is crazy for my Shapeoko2. The data was based in a conversion of a Mach3 xml-file for the MX3660.
Still, my understanding is that I need 50'000 period for a 10kHz signal, which means that it would be convenient to change one of the two. It seems from my hal-file, that both BASE_PERIOD and SERVO_PERIOD are in use.
I presume the only way to get a charge pump running at 10kHz is to set up a separate thread with a period of 50'000?
OJ
OJ
Last edit: 27 Aug 2014 01:35 by olesk. Reason: Further studied revealed cluelessness
- Thank you received: 5270
27 Aug 2014 01:33 - 27 Aug 2014 01:34 #50328
Replied by PCW on topic Changing base/servo thread for 10kHz charge pump
Setting the base thread period to 50,000 should not hurt anything,
worst case you will get real-time delay notifier pop-ups and problems
at high step rates if your CPU cannot run a 20KHz base thread (50000 ns thread period)
The MX3660 is a motor drive not a controller so if you are using a parallel
port to drive the MX3660 you still need a base thread.
Last edit: 27 Aug 2014 01:34 by PCW.
The following user(s) said Thank You: olesk
- olesk
27 Aug 2014 01:36 #50329
by olesk
Replied by olesk on topic Changing base/servo thread for 10kHz charge pump
Ok - thanks for clarifying!
OJ
PS: I was editing the original question as you wrote your answer, but it doesn't matter, as your answer certainly covers it.
OJ
Time to create page: 0.119 seconds
