Velocity change by HAL possible?
- eslavko
- Thank you received: 4
04 Sep 2014 14:39 #50734
by eslavko
Velocity change by HAL possible? was created by eslavko
Hello...
I try to do laser scanner and like to have all program in one file. I just got an idea to somehow tweak the acceleration in X scanning. (laser firing with M62/M63)
For example sequence like this:
G0X0
M62P1 G1X40
M63P1 G1X80
M62P1 G1X120
M63P1 G1X121 (this move too short and traj. planer will decelerate)
M62P1 G1X160
Will slow down at X121 move as segment is shorter than acceleration of machine.
But the machine doesn't need to accelerata/decelerate at all as it's straight move.
So I got the idea to do something like this:
G0X0
G1X5 (the actual acceleration as motor was reversing)
M62P3 (override to fast acceleration)
G1X10 (long enought move to avoid decceleration
Rastering program here
M63P3 (kill fast acceleration)
G1 X(lastX+5) (decelerate ramp)
So actualy when machine got speed I want to set acceleration for this axix to very big value and further M62/63 will make ramp short enought to stay on speed. Just before line end I will restore correct acceleration and make one more move long enought to safely stop the axis.
The only problem I have that I didn't find the hal pin to change the acceleration in live.
Any idea?
G0X0
M62P1 G1X40
M63P1 G1X80
M62P1 G1X120
M62P1 G1X160
G0X0
Any idea?
- ArcEye
- Thank you received: 758
04 Sep 2014 14:57 #50736
by ArcEye
Replied by ArcEye on topic Velocity change by HAL possible?
Hi
Have a read through this thread, we established why you cannot set acceleration on the fly, when emcPT wanted to do something similar, for different reasons
www.linuxcnc.org/index.php/english/forum...-functionality#47283
- eslavko
04 Sep 2014 15:38 #50742
by eslavko
Replied by eslavko on topic Velocity change by HAL possible?
I do check with ini.* and stepgen.* and setp the new walue. Parameter are changed, but real thing on machine doesn't. So values are queued somewhere.
the lookahead in only one line now. But I read somewhere than new TP in developed to have wider lookahead..
...but there must be some nice solution....
- ArcEye
04 Sep 2014 15:46 #50744
by ArcEye
You need to read the thread, they are stored somewhere and are only re-read when reloaded, so changing them makes no difference.
If you have a lot of short segments, the new TP might be better, you will have to try it.
- eslavko
04 Sep 2014 16:20 #50745
by eslavko
I do read... And now I know why my test fail (I do that before I post this thread)
Actulay there are short segments. It may be lot of them of near nill. Raster scanning make segment every time I need to chanhe power of laser.
I didn't try the new TP yet.
Time to create page: 0.090 seconds
