[solved]halui.program.run slow restart
- bkt
- Thank you received: 113
19 Sep 2014 02:46 - 19 Sep 2014 15:45 #51319
by bkt
[solved]halui.program.run slow restart was created by bkt
for me pik&place deltarobot project I thought of two different modes of operation: the easy way is to use a gcode, automatically rewriting it at every new item, and run it using halui.program.run. The hard way is send directly in hal all quotes at axis.n.motor-pos-cmd from a .comp that compute everythings.
So now I work around the use of halui.program.run way .... the work is finish, but I find that there is a long pause between the end of program and the relaunch of the program itself.
Keep in mind that to speed things up I cereate a component that rewrites a part of the gcode for each new position of withdrawal of pik & place and then run the program via a pin connected to halui.program.run out of mypik.hal .
all between the end of a program and its restart pass 0.2-0.4 sec ... a long time for me .... I tried to remove the part of the component that rewrites the gcode for verification . But times remain the same .
you can do something to shorten them ?
the gcode are around 20 rows .
The hard way..... compute and send is not a problem..... but send to axis.n.motor-pos-cmd is the only way?
Last edit: 19 Sep 2014 15:45 by bkt.
- cncbasher
- Thank you received: 288
19 Sep 2014 03:13 #51322
by cncbasher
Replied by cncbasher on topic halui.program.run slow restart
post your project code as an attachment , and lets see what can be done
- newbynobi
- Thank you received: 415
19 Sep 2014 03:42 #51325
by newbynobi
Replied by newbynobi on topic halui.program.run slow restart
@k1
What GUI are you using? Axis is checking the code before executing it, may be that is the delay.
Have you tried sending the commands as MDI instead of using a program? Could be done with a piece of python.
Or using linuxcncrsh
Norbert
Norbert
The following user(s) said Thank You: bkt
- bkt
19 Sep 2014 12:46 #51328
by bkt
Replied by bkt on topic halui.program.run slow restart
yes I use axis GUI.....
and using linuxcncrsh ...... I can make my work simply put in run my program without delay before the start? How can do it?
I can send 20 row of gcode in a single axis-remote --mdi command? but I read in somewhere that is no a better choice ... is not a truth? I need have G64 in my gcode ....Have you tried sending the commands as MDI instead of using
- bkt
19 Sep 2014 16:04 #51333
by bkt
I'm a fool ..... maybe I should get more sleep at night ... obviusly is possible run 200xxxx row gcode in mdi mode ..... if I call the program like a subroutine in ini file
it is also possible to say that a file.comp a subroutine in gcode is in operation...
the easy way to do ... example M120 for signal up and M121 for signal down
than in mycomponent.comp
In this way is possible to run a soubroutine from mycomponent.comp using halui.mdi-command-xx in hal file connecting it to signal out from mycomponent and in the same time control if the soubroutine is in run.
THE FIRST QUESTION OF POST: using this solution I cancel the delay.
I wrote this as a punishment for having opened a post without really need.
@newbynobi and @cncbasher thanks for the time spent
[HALUI]
MDI_COMMAND = o<myprogram> call [xx] [xx] /* <------------- halui.mdi-command-00*/
MDI_COMMAND = M147 /* <------------- halui.mdi-command-01*/
#!/bin/bash
halcmd setp mycomponent.mysignal1 1
#M120 set up mysignal1
exit 0
#!/bin/bash
halcmd setp mycomponent.mysignal1 0
#M121 set down mysignal1
exit 0
pin in bit mysignal1 = 0
if (mysignal1){
/*do something*/
