Precision for internal calculations (gauging issue
- emcPT
- Thank you received: 139
06 Oct 2014 20:22 #51823
by emcPT
Precision for internal calculations (gauging issue was created by emcPT
Today I got an issue where the controller was complaining about an arc that would trigger the gauging error.
The code is automatically generated, that normally do not present errors, but I was checking it with the help of a CAD.
At the end the issue was that one off the coordinates needed to be:
-2.2614
instead of the value that was being used:
-2.261
that was rounded by the software that generated the software.
So, for this particular job, I needed to have 4 decimal places.
My question is where can I change the trigger condition of the gauging error? There is any config value or it needs to be changed on the source code?
Thank you
-2.2614
-2.261
Thank you
- ArcEye
- Thank you received: 758
06 Oct 2014 23:08 #51826
by ArcEye
Replied by ArcEye on topic Precision for internal calculations (gauging issue
Hi
It is in the source code, see
src/emc/rs274ngc/interp_queue.cc
src/emc/rs274ngc/interp_convert.cc
I think it might be a lot of work to change that, can you prevent your CAM from rounding down on arcs ?
The following user(s) said Thank You: emcPT
- emcPT
07 Oct 2014 00:21 #51827
by emcPT
Replied by emcPT on topic Precision for internal calculations (gauging issue
Thank you for the reply.
Yes, I can change the CAM as I made it, but I was hoping that there were a setting on lcnc, as this issue is only a problem on lcnc. Others controllers use the code without triggering the error as I tested, and normally all use only 3 decimals. This way I need to add the number of decimal places to display on the CAM that also give me a lot of work.
- Thank you received: 4994
07 Oct 2014 18:36 #51842
I suspect that the problem is that whoever coded that bit of LinuxCNC was thinking in inches.
4 places of decimals in metric is just silly.
Replied by andypugh on topic Precision for internal calculations (gauging issue
