PLC Tool changer Question
10 Oct 2014 23:10 #51952 by mmt
PLC Tool changer Question was created by mmt
I am going to convert an older cnc machining center to Linux. I have built several commercial machines using it already but this will be my first conversion.
I have a 10 station carousel type tool changer and programming the plc is no problem for me. My question is what is the best / easiest way to pass the tool number requested from Linux to the PLC???
This may have been covered but I could not find it.
Kent
10 Oct 2014 23:12 #51953 by mmt
Replied by mmt on topic PLC Tool changer Question
I forgot to mention that I am using a dedicated Allen Bradley PLC not the PLC in linux.
10 Oct 2014 23:55 #51956 by ArcEye
Replied by ArcEye on topic PLC Tool changer Question
Hi
Have a look at iocontrol
www.linuxcnc.org/docs/devel/html/man/man1/iocontrol.1.html
It outputs that a toolchange is required and the requested tool
11 Oct 2014 01:15 #51957 by BigJohnT
Replied by BigJohnT on topic PLC Tool changer Question
I have a sim tool changer you can look at.
gnipsel.com/linuxcnc/index.html
If this is a mill do you need to orient the spindle?
JT
Time to create page: 0.094 seconds
