About Axis?
- KobeYang
14 Nov 2014 10:34 #53076
by KobeYang
About Axis? was created by KobeYang
Dear sir,
I used emc2.4.7 in ubuntu 10.04 for a long time. and the computer cpu is atom D525(cpu frequency 1.8g dual core).First I meet the latency problem(the user interface is axis and it reported unexpected real-time delay ),then I fellow the instruction which modify the /boot/grub.cfg (set "isolcpus=1",but I did't modify the 2.6.32-122 rtai kernel) and close the HT .Now I meet the new problem:Sometimes when I use the emc2,the MDI can't insert the command.But after I close the emc2 and restart it,the MDI can insert the command again.Is it a CPU problem?need help,thanks a lot!
- BigJohnT
- Thank you received: 1176
15 Nov 2014 00:34 #53088
by BigJohnT
Replied by BigJohnT on topic About Axis?
Does it give you an error message?
JT
JT
- KobeYang
15 Nov 2014 11:01 #53101
by KobeYang
Replied by KobeYang on topic About Axis?
no error message,but the other button is ok,only the MDI line can't insert command by keyboard.
Time to create page: 0.053 seconds
