7I80 Configuration
- LAIR82
- Thank you received: 9
22 Dec 2014 20:30 #54212
by LAIR82
7I80 Configuration was created by LAIR82
Hello Guys,
I am within days of putting power back to a VMC that I just got done stripping the old control and wiring in a new Mesa setup, 7i80-7i52-7i49-7i70-7i71-7i73,
Does anyone have any recent builds using this, that they wouldn't mind sharing there files, I haven't built a 7i80 before, so I am not sure exactly what the base info in the HAL file needs to be to get the 7i80 loaded and running.
Any help would be greatly appreciated,
Rick
Rick
- Thank you received: 5271
22 Dec 2014 23:28 #54221
Replied by PCW on topic 7I80 Configuration
The only necessary hal/ini file difference is that you must specify the IP address of the Ethernet FPGA card
this is done when the hm2-eth driver is loaded, for example:
Note that the firmware is not specified. Like most of Mesa's newer FPGA cards,
the desired firmware is loaded to on-card flash memory once, rather than being loaded
every time linuxcnc starts
There is more system setup information for hm2_eth in its man page:
man hm2_eth
(and of course if you have an existing hal/ini file set you are modifying, you need to change the card name everywhere it occurs)
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_stepgens=5 sserial_port_0=20xxxxxx"
man hm2_eth
23 Dec 2014 08:52 - 24 Mar 2015 08:17 #54241
freeby.mesanet.com/7i80hd_16_rmesvss6_6.bit
Is a 7I80-16 config for a 7I49 on P1 and a 7I52 on P3 so
6 resolver channels and 6 analog outs on 7I49,
6 encoder channels and 6 RS-422 SSerial expansion channels on 7I52
you use the mesaflash utility to update the 7I80 firmware
Last edit: 24 Mar 2015 08:17 by PCW.
- LAIR82
24 Dec 2014 22:55 #54292
by LAIR82
Replied by LAIR82 on topic 7I80 Configuration
Hope fully when we get back from the holiday monday, I will power it up and start hacking away on the files.
Good looking out for me,
I figured it wasn't going to be straight forward with the firmware.
Thanks Peter,
Rick
Thanks Peter,
Rick
- LAIR82
24 Mar 2015 00:07 #57115
by LAIR82
Hello PCW,
Is this firmware part of the software yet? The link is broken, and hopefully within the next week or so, I will be getting to the programming end of my mill project.
Rick
freeby.mesanet.copm/7i80hd_16_rmesvss6_6.bit
Hello PCW,
Rick
24 Mar 2015 00:15 #57116
Sorry, there's a typo in the link:
That bitfile is also in the 7I80.zip support distribution zipfile
- LAIR82
24 Mar 2015 00:19 #57117
by LAIR82
OK,
Thanks Peter,
Like I say, hopefully in the next week or so, I will be getting back to my mill build, I have been working on a 60" VTL install, and a lot of other things, now all of that is almost wrapped up, so I have been watching all of the activity regarding the 7i80 with you and Marius, and I hope it should be a little easier on my end.
Rick
Thanks Peter,
Rick
24 Mar 2015 00:43 - 24 Mar 2015 08:18 #57118
It should go smoother... (famous last words...)
The problem with mariusl's setup was that he was using a very old bit file
(V13 = about 1.5 years old) and I did not realize that there was an issue with
V13 bitfiles that prevents the driver from starting, so it took much too long to
determine the problem...
Last edit: 24 Mar 2015 08:18 by PCW.
Time to create page: 0.205 seconds
