G76 works but not 33
29 Dec 2014 02:28 #54342 by PCW
Replied by PCW on topic G76 works but not 33
OK so in any case the motion.spindle-at-speed need to be looked at (with halmeter or watch)
and if its not getting set, the signals need to be traced backwards
29 Dec 2014 05:15 #54348 by TejasDragon
Replied by TejasDragon on topic G76 works but not 33
Thanks guys, I should get the time tonight to do the changes.
Henry
29 Dec 2014 09:47 #54354 by TejasDragon
No luck yet, just confused. I do not see how to conect signal spindle-at-speed.
I started my config over with just the StepConfig wizard and these are what it gives me
in both hal files.
Henry
************* Lathe.hal *******************************
# Generated by stepconf 1.1 at Sun Dec 28 19:29:42 2014
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x278 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net spindle-at-speed => motion.spindle-at-speed
setp encoder.0.position-scale 60.000000
setp encoder.0.counter-mode 1
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity encoder.0.velocity => motion.spindle-speed-in
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-phase-a encoder.0.phase-A
net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
setp parport.0.pin-14-out-invert 1
net xenable => parport.0.pin-14-out
net spindle-phase-a <= parport.0.pin-10-in
net spindle-index <= parport.0.pin-11-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_2]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable axis.2.amp-enable-out => stepgen.1.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
************************ postgui.hal **************************
# Include your customized HAL commands here
# The commands in this file are run after the AXIS GUI (including PyVCP panel) starts
sets spindle-at-speed true
30 Dec 2014 01:17 #54370 by cncbasher
Replied by cncbasher on topic G76 works but not 33
see attached Hal file ,
and you should see the near function and how to set it etc
30 Dec 2014 03:53 #54380 by TejasDragon
Thanks guys I got it, and have backups of my config in 3 places.
Henry
30 Dec 2014 04:22 #54382 by cncbasher
if you are stuck , attach your config as an archive ( hal and ini )
and i'll take a look
30 Dec 2014 05:34 #54388 by cmorley
Replied by cmorley on topic G76 works but not 33
By the look of the HAL files you posted - it's not the lack of the near component.
spindle-at-speed is set true in the postgui file, so linuxcnc will not wait.
As Peter said, If you check with halmeter if that pin/signal is actually true while running, when we can cross that off the list.
If you could attach _all_ the config files and even the stepconf file that would be great.
And remind me what version of linuxcnc you are using?
Chris M
30 Dec 2014 08:25 - 30 Dec 2014 08:27 #54395 by TejasDragon
It does seem to be working now been running in the air with it, but here is all of my configs.
I bet there is stuff in here I don't need hopefully not something that will mess with it.
linuxcnc ver. 2.6.5
Henry
Last edit: 30 Dec 2014 08:27 by TejasDragon.
Time to create page: 0.072 seconds
