Ignore following errors while homing
03 Jan 2015 00:28 - 03 Jan 2015 00:32 #54499 by awetmore
Replied by awetmore on topic Ignore following errors while homing
As I explained above, the ferror ini parameters _can_ be changed in real time
Awesome!! Thanks, I'll give this a try.
another option suggested by cradek on irc is to use homing to index
(jog to mark perhaps near middle of travel) and then home to index
I'm not sure I understand this concept?
Last edit: 03 Jan 2015 00:32 by awetmore.
06 Jan 2015 07:56 #54626 by andypugh
Replied by andypugh on topic Ignore following errors while homing
It seems like the safest way to handle this is to expect the following error and to ignore them on homing commands. Is there a way to do that?
To throw another option into the mix...
The f-error limits are triggered when the axis.N.motor-pos-fb pin value is too far from the axis.N.motor-position-cmd value.
You get no f-error at all if you connect them directly together.
So, you could use a mux2 component to connect axis.N.motor-pos-fb to _either_ encoder.N.position _or_ axis.N.motor-position-cmd based on the value of axis.N.is-homed....
Time to create page: 0.114 seconds
