[solved] when it is update the _hal - pin
- bkt
- Thank you received: 113
09 Jan 2015 02:17 - 09 Jan 2015 16:47 #54798
by bkt
Replied by bkt on topic how and when the soubrutine takes the _hal - pin
every cycle of while ....#22 etc. #99 is increment of one unit. if greater than 1 it is reset to 0.
there are quite simple, and dont' see the difference if Mcode is in or out if statement......i think the difference is for interpreter or trajectory planner. isn't ?
I think the same of your "short answer" ... I try another trik.
M175 ---> setp ethloop.request 1 /// M176 ----> setp ethloop.request 0
M169 ---> setp ethloop.refresh 1 /// M179 setp ethloop.refresh 0
in ethloop.comp........
if (request)
requestnew(); -----> this function read from ethernet a string of coord from visionsystem server
if (refresh)
fpxuno = ix;
fpyuno = ypsilon;
fpauno = angle; ----->(ix, ypsilon and angle si variabile on requestnew)
Last edit: 09 Jan 2015 16:47 by bkt.
- bkt
12 Jan 2015 16:50 #54918
by bkt
as I showed Mr Dewey Garrett #<_hal[pinname]> never updated during the motion ..... I had not really understood ... so of course need a break or a sync signal but also make a break in the cycle. ( like M66 or similar Mcustom code).
Tanks a lot At all.
Tanks a lot At all.
Time to create page: 0.053 seconds
