option wear tool lathe
- jlviloria
- Thank you received: 12
17 Jan 2015 03:47 #55106
by jlviloria
Replied by jlviloria on topic option wear tool lathe
Dgarret install this version
wget buildbot.linuxcnc.org/dists/wheezy/2.7-r...75.g18a933a_i386.deb
Reproduce the installation steps, and still the same error, I guess stdglue must be a python module, which for some reason is not reading,
with this version of LinuxCNC, does not generate the file in linuxcnc/configs
you think you touch me Formatting? how do I delete all LinuxCNC and reinstall everything from scratch.
thanks,
thanks,
- dgarrett
- Thank you received: 325
17 Jan 2015 04:02 - 17 Jan 2015 04:44 #55107
by dgarrett
Replied by dgarrett on topic option wear tool lathe
Using a deb install:
If you did a make install to /usr, you will have to do it manually since the
Makefile does NOT provide an uninstall option.
However, installing a buildbot deb should overwrite files so that may fix. A
deb install will not remove installed files that are not common to the deb (but
these should be zero or at least few in number).
$ ls
linuxcnc_2.7.0~pre2.275.g18a933a_i386.deb old
$ dpkg --contents *.deb|grep stdglue
-rw-r--r-- root/root 7781 2014-10-29 18:41 ./usr/share/doc/linuxcnc/examples/sample-configs/sim/gmoccapy/python/stdglue.py
drwxr-xr-x root/root 0 2015-01-14 21:07 ./usr/share/linuxcnc/ncfiles/remap_lib/python-stdglue/
-rw-r--r-- root/root 14913 2015-01-14 21:07 ./usr/share/linuxcnc/ncfiles/remap_lib/python-stdglue/stdglue.py
# When using the config selector and creating a config, it makes links in ~/linuxcnc/nc_files to
# the system-provided library directories like remap_lib
$ cd ~/linuxcnc/configs/sim.axis.lathe-fanucy
$ grep stdglue *.ini
PATH_APPEND=../../nc_files/remap_lib/python-stdglue/
$ pwd
/home/username/linuxcnc/configs/sim.axis.lathe-fanucy
$ ls ../../nc_files/remap_lib/python-stdglue
stdglue.py
Last edit: 17 Jan 2015 04:44 by dgarrett.
- joekline9
- Thank you received: 14
23 Jan 2015 12:14 - 21 Feb 2015 05:46 #55281
by joekline9
Replied by joekline9 on topic option wear tool lathe
Using LinuxCNC ver 2.6....
Use G43.2 for wear offset
M6 T1 G43 (Gets tool offsets from tool table.)
G43.1 X.001 (Replaces offset. Does NOT add to it as in docs
G43.2 H10 (adds tool 10's offsets to current offsets as it should
You can have multiple G43.2 H10 lines which will acumulate.
You could set Tool 10 X offset to -.0001
Each line will add another -.0001
Last edit: 21 Feb 2015 05:46 by joekline9.
Time to create page: 0.632 seconds
