Connecting external power-on button to Linux CNC
23 Jan 2015 21:12 - 23 Jan 2015 21:14 #55299 by machete
In my machine (big Gildemeister lathe) i have green button wich is starting machine power (oil pumps, drives power etc) and red button (conected with E-stop) wich turns this power off.
Both buttons connected to different input pins on my 7i77 card.
Now i've configured E-stop (red button), so i can see condition of my external E-stop button in AxisGUI
But, which hal pin i need to connect with my green button to perform action like F2 does?
(At this moment, i must hit F2 first, to start linux-cnc, and after that push green button on my machine)
Last edit: 23 Jan 2015 21:14 by machete.
23 Jan 2015 21:57 #55303 by ArcEye
halui.machine.on
www.linuxcnc.org/docs/html/gui/halui.html
11 Oct 2022 23:37 #253998 by M4MazakUser
Replied by M4MazakUser on topic Connecting external power-on button to Linux CNC
Ok, so now here in 2022, WHAT IS THE MACHINE POWER ON BUTTON CALLED!!
Lol, I a been looking and I can't find anything to link (net) my power on button to.
12 Oct 2022 00:00 #253999 by rodw
There are many ways to do this.
Here is one of them.
forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
But this assumes that the reset button is the orange button in axis.
Probably the correct way is to use a safety relay with a momentary estop reset button (green button) and trigger a relay that sends 24 volts to an input attached to  iocontrol.0.emc-enable-in something like this
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i76e.0.7i76.0.0.input-04
net estop-ext     =>  iocontrol.0.emc-enable-in
Here is my safety relay wiring.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
12 Oct 2022 02:28 #254004 by M4MazakUser
I'm fine with E-stop, it all links and works well, I just want to connect a push button to turn on the button to the right of the e-stop button in axis. The f2 keyboard key links to it. But I can't see what its called. All the axis enables seem to be linked to it.
12 Oct 2022 04:00 #254008 by phillc54
halui.machine.on and halui.machine.off work for AXIS.
12 Oct 2022 05:26 #254013 by M4MazakUser
I tried to net a pin to halui.machine.on
It just created the entity halui. Machine. On.
12 Oct 2022 22:24 #254053 by phillc54
Hmm, it works here, using a 7i96 I connected the pins as below and input 1 will turn the machine on and off.
net power-on  hm2_7i96.0.gpio.001.in      halui.machine.on
net power-off hm2_7i96.0.gpio.001.in_not  halui.machine.off
The following user(s) said Thank You: Masiwood123
17 Oct 2022 05:55 #254326 by M4MazakUser
im going to try a different hal config tomorrow, pretty sure my old one was missing something that set up the halui pins
17 Oct 2022 06:02 #254327 by M4MazakUser
pretty sure this was left out of my .ini file.
HALUI = halui
Time to create page: 0.755 seconds
