Embed a Python/Gtk program
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
27 Jan 2015 22:11 #55386 by BigJohnT
Embed a Python/Gtk program was created by BigJohnT
Does anyone have the basics that are needed to embed a python/gtk program into an Axis tab. I've found EMBED_TAB_NAME and that is pretty straight forward. The EMBED_TAB_COMMAND doesn't seem to have any docs describing how that works. I see a post from ArcEye that the program needs to take a WinID to load. So far I can get the tab to show up but nothing is in the tab.
JT
27 Jan 2015 22:27 #55388 by ArcEye
Replied by ArcEye on topic Embed a Python/Gtk program
Hi JT,
You need to dig into the Axis code to see it clearly.
Axis creates a container window and replaces the {XID} parameter with the actual XWinID
So an INI line such as
EMBED_TAB_COMMAND = xterm -into {XID}
sees xterm called with something like xterm -into 0x7ffcd4f4 where the hex number is the actual winID of the container within the tab widget
I'll dig out the actual Axis line numbers in a bit.
So you need to write a program that can embed itself into a given winID
27 Jan 2015 22:33 #55389 by ArcEye
The code starts at 3285 of Axis in v2.6.6
The bit of code regards the winID is
 for i,t,c in zip(range(len(tab_cmd)), tab_names, tab_cmd):
        w = _dynamic_tab("user_" + str(i), t)
        f = Tkinter.Frame(w, container=1, borderwidth=0, highlightthickness=0)
        f.pack(fill="both", expand=1)
        xid = f.winfo_id()
        cmd = c.replace('{XID}', str(xid)).split()
        child = Popen(cmd)
        wait = cmd[:2] == ['halcmd', 'loadusr']
        _dynamic_childs[str(w)] = (child, cmd, wait)
27 Jan 2015 22:42 #55390 by ArcEye
These give some more info, but my python-fu runs out here
www.pygtk.org/pygtk2tutorial/sec-PlugsAndSockets.html
docs.python.org/2/extending/embedding.html
When I did it in C++ using Qt, I did exactly what I described, created an app that took the ID of the window to embed into as an argument
This is an extract.
#include "HAL_EmbedWidget.h"
int main( int argc, char ** argv )
    QApplication app(argc, argv);
     if (app.arguments().count() != 2) {
         qFatal("Error - expected window id as argument");
         return 1;
     QString windowId(app.arguments()[1]);
     HAL_EmbedWidget window;
     window.embedInto(windowId.toULong());
     window.show();
     return app.exec();
There may be an even simpler way to do it gtk app to gtk app.
  • BigJohnT
  • Administrator
  • Administrator
27 Jan 2015 23:17 #55392 by BigJohnT
Replied by BigJohnT on topic Embed a Python/Gtk program
Thanks for the info, it gives me something to chew on... I seem to remember something Chris said about reparent.
JT
Time to create page: 0.090 seconds
