wj200 vfd - spindle-speed-out to frequency #?
- green751
- Visitor
21 Feb 2015 00:28 #56154
by green751
wj200 vfd - spindle-speed-out to frequency #? was created by green751
Hi, all;
I've been working with my mill rather than on it for a while, running a copy of pre-2.7.0 that I pulled from the git repository a while back. I've reached a point in life where I have a little spare time now and I'd like to establish full spindle speed control with my VFD. Previously I've just been using full speed (I've mostly been cutting aluminum) and the variable speed head.
I've found a couple of issues that I hope will be solved in 2.7.0, so I'm going to take the time to install a clean hard drive and the new ISO image.
Looking at the docs though, one thing isn't any clearer to me from the old version to the new - how do I attach the pins on the wj200 HAL object to the motion object in such a way that spindle-speed-out is converted to an appropriate 0-X hz number to feed to wj200-vfd.0.commanded-frequency?
I did see a reference to a conversion like this in the general docs for VFD modbus setup, but nothing on how to do it. It should be a straightforward bit of math, based on the pole count of the motor in use and the frequency... I know it's possible to read the pole count from the VFD but I don't know if the driver is set up to do it.
Anyone done this or something like it, and have a recipe for it?
Thanks,
Erik
Thanks,
Erik
- Thank you received: 1467
21 Feb 2015 04:49 #56165
Replied by Todd Zuercher on topic wj200 vfd - spindle-speed-out to frequency #?
See man motion9
use
use
motion.spindle-speed-out-rps
- green751
- Visitor
21 Feb 2015 04:54 #56166
by green751
Replied by green751 on topic wj200 vfd - spindle-speed-out to frequency #?
Hmm...
motion.spindle-speed-out-rps OUT float
Desired spindle speed in rotations per second
Okay... maybe I'm too tired to think here, but I can't see how this does much? Is there a spindle-speed-out-hz?
21 Feb 2015 04:57 #56167
Hz is cycles per second, and when referring to revolution speed aka revolutions per second.
- green751
- Visitor
22 Feb 2015 01:58 #56196
by green751
Okay, so then my spindle motor runs at 1725rpm at 60 hz.
To get eg. 1725 rpm on the spindle I'd assume spindle-speed-out-rps is set by HAL to 1725/60 or 28.75. To turn that into the hz command I need for the motor I'd have to multiply it by 2.087 and set wj200-vfd.0.commanded-frequency to the product?
Still not sure how to do this...
22 Feb 2015 03:57 #56200
Then you could use
linuxcnc.org/docs/html/man/man9/mult2.9.html
setp one of the mult2 inputs as the constant you need to multiply by and the other one to spindle-speed-out. Then connect the output of mult2 to your vfd's input.pin.
- green751
- Visitor
23 Feb 2015 22:15 #56237
by green751
Okay, that makes sense. I can basically calculate a constant, then verify the speed of the spindle with a handheld tach and adjust the constant as needed.
I've got the new Debian based install on the control PC now, so I should be able to get this set up tonight.
Thanks!
Erik
Thanks!
Erik
