Multi gear head - semi manual config
22 Feb 2015 03:45 #56199 by dracozny
Multi gear head - semi manual config was created by dracozny
After searching the documentation and looking at a few posts with 2 speed spindle configs I am a bit puzzled on how to go about this.
I have an ZX45 (RF45 clone) which has a 6 speed gear head. and I have a huanyang VFD. The VFD works I can turn it on and off with axis and even vary the speed but the obvious problem is if I am using a lower gear my Feed rates are not calculated correctly.
I do not really have the funds to automate the gear changing, and it's finicky enough doing it by hand. I suppose the easiest answer would be to just ditch the gears and switch to a single speed belt drive, but that's also money out of pocket I don't have atm.
From what I have seen my examples are only automated but I need to do this manually and tell the system what speed it's in, so I am unsure how to proceed. Atm I am running Axis but I am planning on changing to gmoccapy. I'm not sure if that makes a difference in the end.
any ideas?
22 Feb 2015 05:28 #56203 by andypugh
Replied by andypugh on topic Multi gear head - semi manual config
I have 8 speeds on my mill. I choose the gear manually, and then the system works out which gear it is in by looking at the ratio of the spindle-encoder speed and the VFD command.
linuxcnc.org/dapper/index.php/german/for...gear-detection#39583
The following user(s) said Thank You: dracozny
22 Feb 2015 06:25 #56204 by dracozny
Replied by dracozny on topic Multi gear head - semi manual config
I don't have an encoder on my spindle. I suppose I will have to disable the speed control in linuxcnc until I can get an encoder.
22 Feb 2015 06:32 #56205 by andypugh
You can't do tapping without one, and if you have a gearbox it might not be difficult or expensive.
This is Jon Elson's write-up: pico-systems.com/bridge_spindle.html
I did a similar thing with mine. www.cnczone.com/forums/vertical-mill-lat...c-2.html#post1212335
22 Feb 2015 06:49 #56206 by dracozny
I was already fully aware of the rigid tapping issue without an encoder. That feature is very far down my list of needs. Thanks for the info.
22 Feb 2015 06:57 #56208 by andypugh
OK, so if you just want to choose the gear by hand, then just set up a gladeVCP or PyVCP panel with a control on it to set the gear, then take the output of that to a mux that sets the spindle speed to VFD scaling factor.
To drive the mux from the int output of a PyVCP / GladeVCP button you would need to use mux-generic as the other muxes only have bit inputs:
www.linuxcnc.org/docs/html/man/man9/mux_generic.9.html
An alternative to a panel would be to set the gear through G-code, if that works better for you.
Time to create page: 0.098 seconds
