Tx M6 automatic toolchange
- tnl.lambert
24 Feb 2015 03:11 #56249
by tnl.lambert
Tx M6 automatic toolchange was created by tnl.lambert
We are encountering a problem with our machine where the tool table and the requested tool do not seem to produce the correct tool. The process is 100% repeatable, but the tools just don't match the number in the Tx command. I can follow the numbers through the process because I am using a python wrapper for an ngc code that actually does the toolchange. The issue seems to come from the #<selected_pocket> and #<selected_tool> parameters. What mediates the Tx command and the #<selected_pocket> and #<selected_tool> parameters?
Does anyone know how to find out where/why the numbers are being modified? I followed the recommended steps in the Integrator's Manual, using most of the code from '11.5.3 Specifying the M6 replacement'.
Apart from this issue, the toolchange works great.
- ArcEye
- Thank you received: 758
24 Feb 2015 23:56 - 25 Feb 2015 15:02 #56274
by ArcEye
Replied by ArcEye on topic Tx M6 automatic toolchange
Hi
I know little about M6 remapping, having always written realtime components to do the toolchanges, but am quite familiar with the toolchange process.
I have seen problems in the past where the predefined named params are not updated during the program run and I tend to address the hal pins directly these days
if I am getting info via gcode.
Using > 2.7 and defining
[RS274NGC]
FEATURES = 12
you can access the hal pins in the toolchange sequence
#<_hal[iocontrol.0.tool-number]>
#<_hal[iocontrol.0.tool-prep-pocket]>etc
It might be interesting to compare the values returned to the pre-defined params
[RS274NGC]
FEATURES = 12
Last edit: 25 Feb 2015 15:02 by ArcEye.
The following user(s) said Thank You: tnl.lambert
- tnl.lambert
25 Feb 2015 03:26 #56280
by tnl.lambert
Replied by tnl.lambert on topic Tx M6 automatic toolchange
Well, that solved it perfectly. The G-code parameter space wasn't getting the correct info, and the hal pins were. Great!
Time to create page: 0.059 seconds
