Compiling kinematics module in 2.7
16 Apr 2015 23:26 #57844 by bigrig
Compiling kinematics module in 2.7 was created by bigrig
Hi group!
I have a running system with2.4 with a custom 5-axis XXYYZZBC kinematics configuration.
Now I am really interested in trying the "new trajectory planner", so I have made a clean new install with 2.6 and upgraded to 2.7.
The libraries are different from 2.4 so I dont understand where and how to compile my kinematics.c file to get my system up and running.
Can someone please help me?
/Lars
17 Apr 2015 01:09 #57847 by Todd Zuercher
Replied by Todd Zuercher on topic Compiling kinematics module in 2.7
I don't know much about the subject, but I do know that "comp" was renamed "halcompile". Did you catch that little tidbit when you tried to compile your kins?
17 Apr 2015 14:52 - 17 Apr 2015 14:52 #57857 by ArcEye
Replied by ArcEye on topic Compiling kinematics module in 2.7
You have not said what you did in 2.4, so hard to tell exactly.
As Todd said, this is probably what you are missing
www.linuxcnc.org/docs/devel/html/hal/comp.html
(even though the doc name is the same, the command has changed)
Last edit: 17 Apr 2015 14:52 by ArcEye.
Time to create page: 0.314 seconds
