Wait command within python script
21 Apr 2015 21:17 #57972 by binbsoffn
Wait command within python script was created by binbsoffn
Hi there,
i'm using linuxcnc for a 3D-printer.
It all works fine, but there are still some comfort issues:
current state
For printing i need to heat printbed and extruder, which takes at about 10mins.
At the moment i have to sit beside the printer and wait until both have reached target temperature.
And afterwards start the print manually.
target state
I want to automate the wait cycle via a python script, so the printer continues printing after the heating cycle
(other Firmwares use M190 or M109 for set temperature and wait)
Temperature is set and read via a serial interface.
The current script i want to use works fine, if i call it directly from a terminal, but does not work when i call it from within AXIS.
After a few seconds the print just stops completely.
I assume there is some timeout/safetycounter implemented to prevent broken scripts from blocking the whole machine?
How can i get the machine in a waiting state without any timeout?
is there any command in the linuxcnc python module where i can reset this timer?
Should i use M66 or G4 before this script to prevent AXIS from stopping the whole script?
I attached the script i currently work at.
21 Apr 2015 22:21 #57973 by ArcEye
Replied by ArcEye on topic Wait command within python script
Hi
Nothing attached, rename it .txt or put it in a zip to guarantee it gets attached
21 Apr 2015 22:45 - 21 Apr 2015 22:53 #57974 by andypugh
Replied by andypugh on topic Wait command within python script
An alternative way to do this would be in HAL, with a "comp" component for the two temperatures connected to an "and2" which in turn drives the "spindle at speed" input pin or the feed-hold pin. (you would invert the logic and use "or2" in that case)
www.linuxcnc.org/docs/html/man/man9/motion.9.html#PINS
www.linuxcnc.org/docs/html/man/man9/comp.9.html
www.linuxcnc.org/docs/html/man/man9/and2.9.html
[edit] Or the and2 could connect to motion.digital-in-NN and then M66 wait could be used in the G-code (with a long timeout)
Last edit: 21 Apr 2015 22:53 by andypugh.
