5axisgui
- isladelobos
16 May 2015 23:51 - 18 May 2015 21:45 #58762
by isladelobos
5axisgui was created by isladelobos
Hi.
Im interested in modify the 5axisgui because i have XYZBC axes and the file is write protected.
It is possible modify this file witouth problems?
c.newpin("joint0", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint1", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint2", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint3", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint4", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint5", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint6", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint7", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint8", hal.HAL_FLOAT, hal.HAL_IN)
I need delete from joint5 to joint8 because in my hall and ini files i have only 5axes XYZBC 0,1,2,3,4
How is the best method for modify this file?
Thanks.
Thanks.
Last edit: 18 May 2015 21:45 by isladelobos.
- BigJohnT
- Thank you received: 1176
17 May 2015 01:51 #58764
by BigJohnT
Replied by BigJohnT on topic 5axisgui and W axe
Where did you get the file? None of LinuxCNC files are write protected.
JT
JT
- Thank you received: 4994
17 May 2015 04:53 #58767
It ism't write-protected as such, but usr/bin isn't in your "own" folder hierachy.
You can either copy the file to your linuxcnc folder or start gedit in sudo mode from the terminal ( sudo gedit /usr/bin/5axisgui.py )
Replied by andypugh on topic 5axisgui and W axe
Im interested in modify the 5axisgui because i have a normal spindle witouth W axe movement and the file is write protected.
- BigJohnT
17 May 2015 19:04 - 17 May 2015 19:20 #58783
by BigJohnT
The .py extension is dropped on the installed version. So the correct command to edit it would be :
Now that I know what he is talking about lol.Now I wonder what 5axisgui does besides give a RTAPI error when I try and run it.
Nevermind, I found the wiki page on vismach...
JT
JT
Last edit: 17 May 2015 19:20 by BigJohnT.
- BigJohnT
17 May 2015 19:25 #58785
by BigJohnT
To prevent the next update from writing over your changes it is best to copy the file and rename it as you see fit.
Having said that the current copy of 5axisgui only has 5 axes defined...
JT
JT
- isladelobos
18 May 2015 16:55 - 18 May 2015 16:59 #58815
by isladelobos
Replied by isladelobos on topic 5axisgui and W axe
Tnaks masters.
The file was edited sudo nano /usr/bin/5axisgui (i found the correct password)
And correct the file have 5axis not 8axis.
Now I have XYZABC in the front gui. but A axis not exist, im intent to modify 5axisgui, hall & ini files for view XYZBC in the gui but not good results.
Regards.
Regards.
Last edit: 18 May 2015 16:59 by isladelobos.
Time to create page: 0.070 seconds
