- Thank you received: 3
MrFouFou wrote: So; If i'm going to run on 12bits, I will need a pretty fast computer, and a good one; i'm planning to run the servo loop at 6 KHz to match my drive position loop frequency; and increase 7i77 multiplexing speed.
BigJohnT wrote: See comp in the axis section of the ini.
linuxcnc.org/docs/html/config/ini_config.html#sub:AXIS-section
JT
PCW wrote: 3-4 Mhz is possible with the standard (6 foot) cable and a bit of skew adjustment.
also if you only need 3 axis of encoders you can run them non muxed and get
~8 MHz count rate
andypugh wrote: I don't think that increasing the servo thread frequency increases the multiplexing speed. I believe that the multiplexing is between the FPGA card and the adapter card.
If you have to back-off from the 6kHz servo frequency I don't actually think it will matter much.
