Using lincurve to adjust pwm output for spindle
- davidmblackburn
12 Jun 2015 19:11 #59743
by davidmblackburn
Using lincurve to adjust pwm output for spindle was created by davidmblackburn
Does anybody know of an example config that uses lincurve to map/adjust pwm output for spindle speed?
I have a simple opto isolated integrator connected to the output of the pwm pin, scale has been set to the max spindle speed and setting different S values does indeed alter the speed of the spindle via the VFD, but the real spindle speed can be quite a way off what the set speed is and I was wondering if could use lincurve to do a mapping between the set speed via the pwm to the VFD.
- Thank you received: 5013
13 Jun 2015 03:48 #59767
That should work, but I don't know of a sample configuration.
If you can create a little list of what output you need for a range of spindle speeds, then you just need to set those up as the XY points on the lincurve.
If for example
S0 = 0rpm
S250 = 200rpm
S500 = 550rpm
S1000 = 1000rpm
If you had 4 points, to keep it short...
In this example I have done it the lazy way, which might seem backwards, letting the system "choose" the X-values The alternative would be to see what S-value you needed to get your choice of RPMs, but that is more effort.
Replied by andypugh on topic Using lincurve to adjust pwm output for spindle
If for example
S0 = 0rpm
S250 = 200rpm
S500 = 550rpm
S1000 = 1000rpm
loadrt lincurve personality=4
addf lincurve.0 servo-thread
setp lincurve.0.x-val-00 0
setp lincurve.0.y-val-00 0
setp lincurve.0.x-val-01 200
setp lincurve.0.y-val-01 250
setp lincurve.0.x-val-02 550
setp lincurve.0.y-val-02 500
setp lincurve.0.x-val-03 1000
setp lincurve.0.y-val-03 1000
net spindle-raw motion.spindle-out => lincurve.0.in
net spindle-corrected lincurve.0.out => pwmgen.0.in
The following user(s) said Thank You: davidmblackburn
Time to create page: 0.069 seconds
