update parameters (X,Y) from file
- alexlinuxcnc
22 Jun 2015 23:02 #60063
by alexlinuxcnc
update parameters (X,Y) from file was created by alexlinuxcnc
Hello
I am not sure how to attack the problem. Here is my challenge. I would use a camera to take a picture of my working environment. From the picture a software will locate all the components on my image and write out a location file containing all the coordinates of the components. I would like to read in that file containing my coordinates (x,y). The linuxcnc program will move to each new coordinate in a loop. Is there a way for me to reset the the coordinates, G0 X$1 Y$2, where $1 and $2 are read from file?
Thank you,
Alex
Thank you,
Alex
- ArcEye
- Thank you received: 758
23 Jun 2015 13:19 #60081
by ArcEye
Replied by ArcEye on topic update parameters (X,Y) from file
Sounds like you are writing your own pick and place machine.
Others have done similar before.
If you are going to generate the co-ordinates separately, you are probably going to either have to use them to write a proper gcode file and run it, or use them piecemeal via axis-remote MDI commands.
- alexlinuxcnc
23 Jun 2015 22:30 #60093
by alexlinuxcnc
Replied by alexlinuxcnc on topic update parameters (X,Y) from file
Dear ArcEye,
Thank you for your ideas. I will try.
Thank you.
Thank you.
- ArcEye
24 Jun 2015 14:45 #60107
by ArcEye
If you go the write a gcode file route, I have some unofficial Axis mods at
mgware.co.uk/ > Axis Modifications
Amoungst them is the facility to run a file remotely, as well as load it remotely from axis-remote
The zip contains replacement files for 2.5.3 and 2.6.3, which should work in any subversions of those major versions
The following user(s) said Thank You: alexlinuxcnc
- alexlinuxcnc
29 Jun 2015 20:23 #60249
by alexlinuxcnc
Dear ArcEye,
Thank you for sharing your infinite wisdom. God does not answer me this quick.
I will study your file today.
Sincerely,
Alex
Sincerely,
Alex
- ArcEye
29 Jun 2015 20:29 #60251
by ArcEye
Oh I am quite sure it is finite, I may have exceeded my quota already
Time to create page: 0.814 seconds
