Pause function for use with a router
- dgarrett
- Thank you received: 297
28 Jun 2015 19:09 - 28 Jun 2015 19:46 #60231
by dgarrett
Replied by dgarrett on topic Pause function for use with a router
There are more than 8 example Sim configurations in 2.7. Each has a text file and there is an overall Readme with some instructions
See the directory:
configs/sim/axis/moveoff
More detailed instructions are at:
www.linuxcnc.org/docs/2.7/html/config/moveoff.html
Three is a manpage for the component:
www.linuxcnc.org/docs/2.7/html/man/man9/moveoff.9.html
See the directory:
Last edit: 28 Jun 2015 19:46 by dgarrett.
The following user(s) said Thank You: rszemeti
- rszemeti
- Visitor
28 Jun 2015 22:52 - 29 Jun 2015 01:04 #60235
by rszemeti
Replied by rszemeti on topic Pause function for use with a router
The "z_retract" example looks like it might work, one question ... if the retract distance is pre-set and you bang the pause button when the axis is already fully retracted (eg when moving between fixtures) ... what happens then? out of limits error?
what I was wondering is if there was some way to feed the pin that has the value of the retract distance with the distance the joint is currently from its zero position
so sorta
joint.2.position -> x by -1 -> feed into z retract distance pin
would that be doable and make it retract just the right amount?
so sorta
Last edit: 29 Jun 2015 01:04 by rszemeti.
- Thank you received: 1482
29 Jun 2015 04:36 #60240
Replied by Todd Zuercher on topic Pause function for use with a router
I haven't looked at it myself and don't know how it works, but hopefully it retracts to (or can be configured to use) a G53 machine coordinate position, there for making the position, offsets, and coordinate systems irrelevant when the retract is called.
- rszemeti
- Visitor
29 Jun 2015 11:02 #60246
by rszemeti
I don't think it can do a G53 style move as that is part of the interpreter, this is a HAL only implementation, so as I understand it, it doesn't know about things like softlimits, workspace offsets etc.
AFAIK, you one of the dangers of this module is that you can jog into the hard limits of the machine ...
- jtc
- Thank you received: 12
30 Jun 2015 00:15 - 30 Jun 2015 00:17 #60268
by jtc
Some time ago ArcEye create a "hack" that make possible do this. There is a discussion thread on this forum somewhere...
edited:
seeing the video closely, the MDI can“t be executed randomly...
Replied by jtc on topic Pause function for use with a router
edited:
Last edit: 30 Jun 2015 00:17 by jtc.
- dremeier
19 Jan 2020 09:12 #155154
by dremeier
Replied by dremeier on topic Pause function for use with a router
@rszemeti
did you find a working solution?
I would prefer the same function on pause as you!
Time to create page: 0.375 seconds
