Feed rate value for AXIS
18 Jul 2015 02:54 #60707 by FiliP
Feed rate value for AXIS was created by FiliP
I saw small widget on main screen gmoccapy, where feed rate is calculated and shown.
I want do the same for my AXIS and gladevcp widget, but i cant find anything about how it is done, on the web.
I looked into testing (sim) configuration, but get no luck.
There is no HAL pin with current FEED.
Any hints?
18 Jul 2015 08:09 - 18 Jul 2015 08:09 #60711 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Feed rate value for AXIS
You can get the velocity of the cutter from the pin
motion.current-vel
This is in machine units per second so you would have to scale it to what you want to see.
Last edit: 18 Jul 2015 08:09 by LearningLinuxCNC.
The following user(s) said Thank You: FiliP
18 Jul 2015 15:29 - 18 Jul 2015 15:30 #60715 by FiliP
Replied by FiliP on topic Feed rate value for AXIS
Thx, found it , and it works.
My mistake was searching something like "feed".
Last edit: 18 Jul 2015 15:30 by FiliP.
17 Mar 2016 21:59 #71830 by FiliP
Hi.
My feed rate slider dont work since i bought XHC HB04. Can anyone help me with this situation? :dry:
We have this:
pendant:feed-value
                         <== motion.current-vel
                         ==> xhc-hb04.feed-value
Before HB04 i was using this:
loadrt	mult2	count=2
addf	mult2.0		servo-thread
addf	mult2.1 	servo-thread
setp	mult2.0.in0	60
net	ips-in1		mult2.0.in1				<= motion.current-vel
net	ipm-out1	gladevcp.hal_feedspeedbarcurrent	<= mult2.0.out
setp	mult2.1.in0	60
net	ips-in2		mult2.1.in1				<= motion.requested-vel
net	ipm-out2	gladevcp.hal_feedspeedbarset		<= mult2.1.out
Now i have this error:
rpanel.hal:14: Pin 'motion.current-vel' was already linked to signal 'pendant:feed-value'
I'v tryed using pendant:feed-value, pendant.feed-value or xhc-hb04.feed-value instead motion.current-vel, but this dont work. I cant get through this... :(
18 Mar 2016 15:22 #71869 by andypugh
Replied by andypugh on topic Feed rate value for AXIS
A pin can't connect to more than one signal.
But, that's OK, just use pendant.feed-value everywhere you want that pin value. In this case
net	pendant.feed-value		mult2.0.in1
18 Mar 2016 18:56 #71877 by FiliP
Yes, i knew it but didnt know how to use this knowlege :) So i can have one pin to signal, but one signal to many pins... So i must know what is signal, what is pin... Thank you.
It didnt work but this work:
net	pendant:feed-value		mult2.0.in1
Thank you again andypugh :)
Time to create page: 0.472 seconds
