Motion Feed Hold Without Arc-OK
29 Jul 2015 05:09 #61007 by Paul
Replied by Paul on topic Motion Feed Hold Without Arc-OK
Hey ArcEye. I believe you got me there! After initial testing without plasma cutter on, I can get the feed to hold. I took your first set of code and inverted the arc-ok signal. That will allow axis to move into position, touch off to find top of material, enable torch relay and then just hold... and hold... While it was holding, I jumpered the arc-ok pins and feed hold released and axis movement continued. I will test fully in the next day or two.
As before, thank you very much!!!
Paul
01 Aug 2015 03:06 - 01 Aug 2015 03:11 #61077 by mkardasi
Replied by mkardasi on topic Motion Feed Hold Without Arc-OK
Paul,
You can also use M66 to check your Arc-OK signal. Here is an example that waits 5 seconds after the Torch is fired. If it doesn't sense Arc-OK true then it posts a message and pauses the program.
M3 S1     (Fire Arc)
M66 P0 L3 Q5     (Wait for a high state on motion.digital-in-00 for up to 5sec)
O991 IF [#5399 EQ -1]     (If M66 timeout while waiting)
     M5      (Torch Off)
    (MSG, Arc Start Fail! Program Paused.)     (Post a message to GUI)
     M0      (Pause the program)
O991 ENDIF
You would have to add this connection to your HAL file (assuming digitalin-00 is not assigned to something else)
net ArcOK <= motion.digital-in-00
You could use the above G-code as an external subroutine which is called instead of M3.
Last edit: 01 Aug 2015 03:11 by mkardasi.
02 Aug 2015 08:56 #61117 by Paul
Thanks Guncotton,
That is what I was using, but that only checks once. I was wanting a way to check for the Arc-OK at all times when the torch is activated.
But thanks for mentioning it,
Paul
02 Aug 2015 18:19 #61120 by BigJohnT
Replied by BigJohnT on topic Motion Feed Hold Without Arc-OK
Thanks Guncotton,
Paul
You can do that in HAL.
JT
03 Aug 2015 22:47 #61142 by Paul
With ArcEye's work, I think I have it now where motion is halted if the arc-ok signal drops while cutting (or never existed from the beginning of an arc start).
I ran it this weekend and did not have a negative effects like halted motion when it shouldn't have halted.
Is there another way? I'm using and2 and inverted arc-ok signal to accomplish the motion-hold.
OK
Time to create page: 0.098 seconds
