New Robot Configuration Compile Error [Solved]
13 Aug 2015 22:24 #61383 by andypugh
Replied by andypugh on topic New Robot Configuration Compile Error
Does irb.ko exist anywhere?
Did you add it to the makefile in both places?
13 Aug 2015 23:45 - 13 Aug 2015 23:52 #61385 by ArcEye
Replied by ArcEye on topic New Robot Configuration Compile Error
/home/asea/Documents/Files/Source/build/bin/linuxcnc_module_helper: Invalid usage with args: remove irb6
Your module is called irb.ko, so why is it trying to remove something called irb6?
Answer, because you have called your module one thing and your component another
int rtapi_app_main(void) {
    int res=0;
    comp_id = hal_init("irb6");
    if (comp_id < 0) return comp_id;
Either change the file names to irb6 and change the Makefile enties too, or more simply change the component name so it is the same as the module name.
When you tell halcmd to loadrt irb, it expects that the module name will be irb and all sorts of problems then ensue when it isn't.
There is now a check in halcompile (comp) which rejects comps which have a different file and component name, for that reason.
If that was all that was wrong, hopefully will sort it
Last edit: 13 Aug 2015 23:52 by ArcEye.
The following user(s) said Thank You: jstoquica
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
13 Aug 2015 23:45 #61386 by jstoquica
Replied by jstoquica on topic New Robot Configuration Compile Error
Initially not, but I edit Makefile and then generates next error:
Machine configuration directory is '/home/asea/Documents/Files/Source/build/configs/irb'
Machine configuration file is 'puma560.ini'
Starting LinuxCNC...
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists
Realtime system did not load
Usage: /home/asea/Documents/Files/Source/build/bin/linuxcnc_module_helper insert /path/to/module.ext [param1=value1 ...]
where module is one of:
	rtai_math
	rtai_sem
	rtai_shm
	rtai_fifos
	rtai_up
	rtai_lxrt
	rtai_hal
	rtai_sched
	rtai_smi
	rtai
	rt_mem_mgr
	adeos
	rtl_time
	rtl_sched
	rtl_posixio
	rtl_fifo
	rtl
	mbuff
the path starts with one of:
	/lib/modules
and the extension is one of:
	.ko
or the module is in the directory /home/asea/Documents/Files/Source/build/rtlib
OR
/home/asea/Documents/Files/Source/build/bin/linuxcnc_module_helper remove module
where module is one of the modules listed above.
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
ERROR: Module hal_lib is in use by irb
ERROR: Module rtapi is in use by hal_lib
ERROR: Module rtai_math is in use by irb,rtapi
ERROR: Module rtai_sem is in use by rtapi
ERROR: Module rtai_fifos is in use by rtapi
ERROR: Module rtai_sched is in use by rtapi,rtai_sem,rtai_fifos
ERROR: Module rtai_hal is in use by rtapi,rtai_sem,rtai_fifos,rtai_sched
Cleanup done
LinuxCNC terminated with an error.  You can find more information in the log:
    /root/linuxcnc_debug.txt
and
    /root/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Now, any configuration has the same error, I think when forget add *.ko initially the kernel was deconfigured, I will try with a new copy of linuxcnc. Or what other solution do you consider?
13 Aug 2015 23:55 #61387 by ArcEye
Re-boot and start again, don't forget to go into a terminal, cd to your RIP and run . ./scripts/rip-environment first
If rt modules get orphaned and stuck in memory, you can't remove them like userland processes, sometimes only a reboot will do it
  • jstoquica
  • Premium Member
  • Premium Member
14 Aug 2015 02:10 #61390 by jstoquica
One mistake and everything is wrong.
Now I got to generate a simulation of the robot, I have some errors with vismach model but here is not the topic. Thanks a lot guys.
14 Aug 2015 05:13 #61392 by andypugh
Yes, filename and comp name not matching is such a hard bug to spot (the errors messages are no help) that I think there is now a warning about it in comp / halcompile.
Time to create page: 0.097 seconds
