Copying example tool change info to my configurati
- yugami
18 Aug 2015 04:50 #61494
by yugami
Copying example tool change info to my configurati was created by yugami
I'm trying to port over sim.axis.remap.manual-toolchange-with-tool-length-switch to my configuration. However Simulated-home.hal is conflicting with my home switches. What is this file doing? I don't speak fluant HAL, can this file be ignored?
- BigJohnT
- Thank you received: 1176
18 Aug 2015 05:06 #61495
by BigJohnT
Replied by BigJohnT on topic Copying example tool change info to my configurati
You should only copy the parts that you need to your config, trying to "convert" a sim can be confusing. Simulated home does just what it says it simulated the home switches.
JT
JT
- yugami
18 Aug 2015 07:45 #61499
by yugami
Replied by yugami on topic Copying example tool change info to my configurati
Well I'm trying to only copy the parts I need, but theres basically nothing explaining what each of the parts are so thats why I asked.
Time to create page: 0.120 seconds
