Print Kinematics Parameters in LinuxCNC Simulation
11 years 2 months ago #61500 by jstoquica
Recently I finished the simulation assembly of the IRB6 manipulator in vismach, and then I tried to test the properly kinematic, but the performance of the simulation is not good. I need to analyse the results of the kinematic parameters file.
How can I generate a log file with the kinematics variables in the simulation? Is It possible in linuxCNC? Or What other way do you recommend to me?
Regards.
11 years 2 months ago #61576 by andypugh
If the numbers you need appear on HAL pins then you can log them with halsampler, or possibly with halscope.
The following user(s) said Thank You: jstoquica
11 years 2 months ago - 11 years 2 months ago #61635 by jstoquica
Thanks for the reply,
I want to know the values of the kinematics variables, like angles values (theta) when I type G commands. For to check the real computations of kinematics functions in the *.c file. Is It possible in the functions like kinematicsForward or kinematicsInverse?
If it's possible, how can I do that?
else, how can I check them?
Regards.
Last edit: 11 years 2 months ago by jstoquica.
11 years 1 month ago #62291 by jstoquica
I hope you can help me with. Can I use something like that for generate the results of the kinematics variables?:
#include <stdio.h> int main(void) { char log[]="LogIRB.txt"; FILE *arq; arq = fopen(log, "a"); if(arq == NULL) printf("Erro, nao foi possivel abrir o arquivo\n"); else{ fprintf(arq, "X= %.2f\n", variavelX ); } fclose(arq); return 0; }
Regards.
11 years 1 month ago - 11 years 1 month ago #62292 by andypugh
You can't access files from kernel modules, and kinematics routines are real-time kernel modules.
All you can do it print to the kernel log (i.e., dmesg). This is a Linux limitation, not a LinuxCNC one.
hal_sampler and sampler together circumvent this via a shared-memory buffer.
[Edit]
You might be able to print to file from a sim or uspace config, but not an RTAI config
Last edit: 11 years 1 month ago by andypugh.
10 years 11 months ago #65710 by jstoquica
Hi everyone,
In "genserkins.c" file the main () function has some printf() or fprintf() functions like:
fprintf(stderr, "bad value: %s\n", argv[2]); printf("initial estimate for Cartesian position, xyzrpw: "); printf("calculation time: %f secs\n", (end - start));
How can I verify those log results when run a simulation? and/or how can I generate o text file with sim config without RTAI config?.
Thanks.
Time to create page: 5.291 seconds
