Homing the Spindle
- REEEN
28 Aug 2015 15:25 #61863
by REEEN
Homing the Spindle was created by REEEN
Hello guys,
Iam currently converting a machine with a toolchanger which needs spindle orientation.
Doing spindle orientation with the spindle orient component is pretty easy, but there is one problem, the orient component does not use the index signal of the spindle, so the spindle will be oriented by the position the spindle is placed when the machine is turned on.
So I need to home the spindle using the index signal, this is also no problem.
But I can only do this with a component or mdi command or m command..
There is no possibility to make sure the spindle is homed when a toolchange is done.
How can I force spindle homing like axis homing before running any commands or programmes ?
Any idea ?
Thank you !
Any idea ?
Thank you !
- ArcEye
- Thank you received: 240
31 Aug 2015 11:04 #61933
by ArcEye
Replied by ArcEye on topic Homing the Spindle
I can only suggest that you have a good read through Thomas's thread on converting his spindle to use orient for toolchanging
www.linuxcnc.org/hardy/index.php/english...3-works?limitstart=0
I think he got it working properly, so that the spindle oriented to the home position for a tool change.
- Thank you received: 4658
01 Sep 2015 16:13 #61999
To home the spindle you need to set the spindle encoder index-enable pin high, then rotate the spindle past the index.
There are a number of ways that this could be done, but none currently exist as a built-in part of LinuxCNC. I have raised a feature request
sourceforge.net/p/emc/feature-requests/138/
I need to experiment when at a machine, but it is possible that a G33 command in startup G-codes might have the desired effect.
Or, potentially, linking a G33 as an MDI_COMMAND to the X-axis is-homing pin.
Replied by andypugh on topic Homing the Spindle
- REEEN
02 Sep 2015 09:17 #62041
by REEEN
Replied by REEEN on topic Homing the Spindle
Hello Andy,
Thanks for your reply.
I managed to solve the problem with a remap procedure and some mcodes running bash scripts.
I remapped toolchange to home the spindle before the change but only once, I used some bash scripts to check whether spindle is homed and if so my routine will skip homing to save time.
But a build in spindle homing procedure would be the best !
Connecting a homing axis with a mdi command is not possible because mdi commands cannot be run before axis are homed, because the need to access the mdi mode and that's not possible before axes are homed.
02 Sep 2015 11:36 - 02 Sep 2015 11:44 #62043
[quote="REEEN" post=62041I managed to solve the problem with a remap procedure and some mcodes running bash scripts.
Connecting a homing axis with a mdi command is not possible because mdi commands cannot be run before axis are homed[/quote]
Ah, yes, that does complicate matters.
<thinking aloud>
You can "sets" the spindle-index-enable in the HAL file.
If the position-control loop was arranged to output a fixed spindle speed if the index-enable was still set when position mode was enabled, then the spindle would first move through index before aligning itself.
This could be done with a mux2, I _think_ that the mux2.N.sel pin can be connected to the index-enable signal, but I am not 100% sure.
One would have to be careful to consider the case in a specific HAL file where the spindle was in velocity mode for rigid tapping (as an example) where the index-enable pin goes high before the start of the move.
In the typical setup:
You could replace the circled Mux2 with a Mux4, and connect position-mode-and-index-enable-set to a fixed speed, position-mode-and-not-index-enable to the position pid, and the other two inputs to the velocity pid.
If you are using Master then you might like to note that there are new pins in the orient component to drive the motion.spindle-is-oriented inputs:
orient.N.is-oriented bit out orient.N.tolerance float in www.linuxcnc.org/docs/devel/html/man/man9/orient.9.html
I possibly should have added them in 2.7, but didn't. You could halcompile --install the Master version if you wanted to.
<thinking aloud>
Last edit: 02 Sep 2015 11:44 by andypugh.
- REEEN
02 Sep 2015 12:16 #62044
by REEEN
Yes, the way you described looks possible.
But I prefer my way with remapping and bash scripts, it was less work.
I don't use master, but the new pins are very good, I did exactly the same with a near component to ensure spindle is oriented right when the toolchange starts.
A lot of machines use tool changers where a spindle orientation musdt be done and I think inserting pins for spindle homing in motion is a useful thing.
Greets Rene
Greets Rene
02 Sep 2015 12:44 #62046
I think that the HAL way is less work if you are doing it as part of the HAL setup, rather than adding it later.
Basically all that changes is that the mux2 that chooses between the PID outputs becomes a mux4.
- LearningLinuxCNC
- Thank you received: 39
02 Sep 2015 15:35 #62057
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Homing the Spindle
Andy,
Sorry to hijack but I must know.
How did you generate the HAL diagram in the above post?
02 Sep 2015 16:17 #62059
By hand. I did it some time ago for the Wiki.
The component tables were copy-pasted from halcmd to Excel, then formatted and aligned there, and copied to Inkscape where the arrows were added.
- LearningLinuxCNC
02 Sep 2015 16:20 #62060
by LearningLinuxCNC
I was laying awake last night thinking of ways to do that automatically by reading the HAL files in a config. May be an upcoming programming project for me. I thought there might already be a tool out there for it.
Time to create page: 0.145 seconds
