Kinematics modification
15 Sep 2015 00:37 #62573 by tommy
Kinematics modification was created by tommy
What would be the proper way to inverse certain axis in kinematics module? I would need to modify 5axiskins.c module:
5axiskins
For now I would have to inverse X axis (joints[0]), as it happens now for example, when apply G0 B40, the X axis moves in wrong direction, and that happens when angular axis require linear axis to move along.
All axis are programmed correctly and are moving correctly as long as G-code is simple 3-axis (X,Y,Z)
15 Sep 2015 17:38 - 15 Sep 2015 17:39 #62609 by andypugh
Replied by andypugh on topic Kinematics modification
Before modifying the kinematics file, have you tried using a negative pivot-length?
Also, I believe that the 5-axis kinmeatic modules expect the tool length offset to be in the W column of the tool table, not the Z column.
Last edit: 15 Sep 2015 17:39 by andypugh.
15 Sep 2015 18:34 #62611 by tommy
Replied by tommy on topic Kinematics modification
Will give it a try with negative pivot length, I didn't think of that ....
5axiskins takes tool length from W column of the tool table, which is in my case filled automatically after measuring tool length on tool sensor, and after that G43Hn etc... and this number is added to a number which is already in kinematics module and represents fixed distance of pivot, in my case distance from center of rotation of B-axis to the end of tool holder, so sum of this two numbers should give negative value to try this out.
16 Sep 2015 21:49 #62641 by tommy
Negative value didn't help... I think I have somewhere else something wrong as also in preview window B-axis moves in opposite direction as it should.
+/- Jog is moving in correct directions for all axes...
16 Sep 2015 22:00 #62642 by andypugh
Ok, then it might be time to modify the kinematics file.
You can probably compile/install it with halcompile.
Do you have the kinematics file, and do you understand it?
16 Sep 2015 22:38 #62644 by tommy
Kinematics that I use is:
* Description: my5axiskins.c
*   Trivial kinematics for 3 axis Cartesian machine
*   Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2007 Chris Radek
* Last change:
#include "kinematics.h"		/* these decls */
#include "posemath.h"
#include "hal.h"
#include "rtapi_math.h"
#define d2r(d) ((d)*PM_PI/180.0)
#define r2d(r) ((r)*180.0/PM_PI)
struct haldata {
    hal_float_t *tool_length;
    hal_float_t *pivot_length;
} *haldata;
static PmCartesian s2r(double r, double t, double p) {
    PmCartesian c;
    t = d2r(t), p = d2r(p);
    c.x = r * sin(p) * cos(t);
    c.y = r * sin(p) * sin(t);
    c.z = r * cos(p);
    return c;
int kinematicsForward(const double *joints,
		      EmcPose * pos,
		      const KINEMATICS_FORWARD_FLAGS * fflags,
		      KINEMATICS_INVERSE_FLAGS * iflags)
    PmCartesian r = s2r(*(haldata->pivot_length) + joints[8], joints[5], 180.0 - joints[4]);
    pos->tran.x = joints[0] + r.x;
    pos->tran.y = joints[1] + r.y;
    pos->tran.z = joints[2] + *(haldata->pivot_length) + r.z;
    pos->a = joints[3];
    pos->b = joints[4];
    pos->c = joints[5];
    pos->u = joints[6];
    pos->v = joints[7];
    pos->w = joints[8];
    return 0;
int kinematicsInverse(const EmcPose * pos,
		      double *joints,
		      const KINEMATICS_INVERSE_FLAGS * iflags,
		      KINEMATICS_FORWARD_FLAGS * fflags)
    PmCartesian r = s2r(*(haldata->pivot_length) + pos->w, pos->c, 180.0 - pos->b);
    joints[0] = pos->tran.x - r.x;
    joints[1] = pos->tran.y - r.y;
    joints[2] = pos->tran.z - *(haldata->pivot_length) - r.z;
    joints[3] = pos->a;
    joints[4] = pos->b;
    joints[5] = pos->c;
    joints[6] = pos->tran.y -r.y;
    joints[7] = pos->v;
    joints[8] = pos->w;
    return 0;
/* implemented for these kinematics as giving joints preference */
int kinematicsHome(EmcPose * world,
		   double *joint,
    *fflags = 0;
    *iflags = 0;
    return kinematicsForward(joint, world, fflags, iflags);
KINEMATICS_TYPE kinematicsType()
    return KINEMATICS_BOTH;
#include "rtapi.h"		/* RTAPI realtime OS API */
#include "rtapi_app.h"		/* RTAPI realtime module decls */
#include "hal.h"
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsForward);
EXPORT_SYMBOL(kinematicsInverse);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
    int result;
    comp_id = hal_init("my5axiskins");
    if(comp_id < 0) return comp_id;
    haldata = hal_malloc(sizeof(struct haldata));
    result = hal_pin_float_new("my5axiskins.tooloffset.z", HAL_IN, &(haldata->tool_length), comp_id);
    if(result < 0) goto error;
    result = hal_pin_float_new("my5axiskins.pivot-length", HAL_IO, &(haldata->pivot_length), comp_id);
    *(haldata->pivot_length) = 100;
    hal_ready(comp_id);
    return 0;
error:
    hal_exit(comp_id);
    return result;
void rtapi_app_exit(void) { hal_exit(comp_id); }
compiling is done with:
halcompile --install m5axiskins.c
But I'm a bit cautious about modifying it...
16 Sep 2015 22:45 #62645 by andypugh
You will get hard-to-understand errors if the comp_id and file name don't match.
16 Sep 2015 23:18 - 16 Sep 2015 23:19 #62646 by tommy
Recently I was checking basic 5axis kinematics with running SIM-5-AXIS configuration and noticed that there also B axis rotates counter clockwise in positive direction (referenced by Y-axis direction), and that is opposite as A and C axis rotation referenced to their center axis ( X and Z)...
Mybe I'm totally wrong, but I think this is the correct (basic) coordinate system with angular axis included:
Last edit: 16 Sep 2015 23:19 by tommy.
17 Sep 2015 16:28 #62677 by andypugh
The original kins was written (I think) for a turntable-C + tilting head machine which might explain that. I think the sim config is a gantry?
17 Sep 2015 17:12 #62683 by tommy
SIM config is gantry and also "head-head" design of BC axis (same as mine), so I could use it's kinematics module, except rotation of B-axis should be inverted somehow ...
I know I could invert B-axis with postprocessor but I think it would be better if it is done by kinematics so all angular axis are rotating clockwise.
Time to create page: 0.393 seconds
