help for angular axis config
27 Sep 2015 06:32 #63043 by cabocozika
help for angular axis config was created by cabocozika
hi,
I try to config my a axis, but i dont know how do scale it in velocity mode
need help for this
motor ac 3ph
inverter pin1=enable
pin2=frequency
pin3=direction
encoder 20 counts
Generated by stepconf at Fri Sep 25 09:14:15 2015
# overwritten when you run stepconf again
[EMC]
MACHINE = my-mill
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/ee/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 51600
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 4
COORDINATES = X Y Z A
MAX_ANGULAR_VELOCITY = 1352.00
DEFAULT_ANGULAR_VELOCITY = 60.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 10.00
MAX_LINEAR_VELOCITY = 100.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 95.0015197638
MAX_ACCELERATION = 1000.0
STEPGEN_MAXACCEL = 1250
SCALE = 96.89767
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 37.5
SCALE = 20
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = 20
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -4.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
MAX_VELOCITY = 65
STEPGEN_MAXACCEL = 20
MAX_ACCELERATION = 20
PID_MAX_VEL = 66
BACKLASH = 0.000
SCALE = 11.1111
ENCODER_SCALE = 80
OUTPUT_SCALE = 1.000
MIN_LIMIT = -99999999
MAX_LIMIT = 99999999
FERROR = 1
MIN_FERROR = .5
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0.0
HOME_LATCH_VEL = 0.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
DEADBAND = 0.046
P = 150
I = 100
D = 0.1
BIAS = 0
FF0 = 0
FF1 = 1
FF2 = 0
# Generated by stepconf at Fri Sep 25 09:14:15 2015
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
loadrt stepgen step_type=0,0,0,0 ctrl_type=p,p,p,v
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net spindle-brake <= motion.spindle-brake
setp parport.0.pin-01-out-invert 1
net spindle-brake => parport.0.pin-01-out
net xdir => parport.0.pin-02-out
net xstep => parport.0.pin-03-out
net adir => parport.0.pin-14-out
setp parport.0.pin-16-out-invert 1
net astep => parport.0.pin-16-out
setp parport.0.pin-17-out-invert 1
net xenable => parport.0.pin-17-out
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 1
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
###### pid
loadrt pid num_chan=1
addf pid.0.do-pid-calcs servo-thread
setp pid.0.Pgain [AXIS_3]P
setp pid.0.Igain [AXIS_3]I
setp pid.0.Dgain [AXIS_3]D
setp pid.0.bias [AXIS_3]BIAS
setp pid.0.FF0 [AXIS_3]FF0
setp pid.0.FF1 [AXIS_3]FF1
setp pid.0.FF2 [AXIS_3]FF2
setp pid.0.deadband [AXIS_3]DEADBAND
setp pid.0.maxoutput [AXIS_3]PID_MAX_VEL
####ddt
loadrt ddt count=4
####encoder
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.0.counter-mode 1
setp encoder.0.position-scale [AXIS_3]ENCODER_SCALE
net enc0A encoder.0.phase-A <= parport.0.pin-10-in
net enc0B encoder.0.phase-B <= parport.0.pin-15-in
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.maxvel [AXIS_3]MAX_VELOCITY
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 1
setp stepgen.3.dirhold 35000
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
net Apos-fb => pid.0.feedback
net Apos-fb <= encoder.0.position
net Apos-fb => axis.3.motor-pos-fb
net Aoutput => stepgen.3.velocity-cmd
net Aoutput <= pid.0.output
net Apos-cmd <= axis.3.motor-pos-cmd
net Apos-cmd => pid.0.command
net Aenable => stepgen.3.enable
net Aenable <= axis.3.amp-enable-out
net Aenable => pid.0.enable
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net Aoutput ddt.0.in
net Apos-fb ddt.1.in
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
28 Sep 2015 04:09 #63090 by andypugh
Replied by andypugh on topic help for angular axis config
Can you say how what you get is different from what you expect?
In fact, can you describe what you are trying to do?
What sort of machine is this? Why are you trying to configure the A axis in velocity mode? Do you also want to be able to operate it in position mode? (with a 20 count encoder, I expect not)
28 Sep 2015 16:38 #63119 by cabocozika
Replied by cabocozika on topic help for angular axis config
thanks for reply
my machine and wind power transformer
i dont need very precision
+- half turn im very happy
28 Sep 2015 18:06 #63130 by andypugh
You still haven't asked a question that I know how to answer.
How does what you get differ from what you expect?
28 Sep 2015 20:03 #63139 by cabocozika
ok
i need turn counts
but i dont know how i do
thanks
28 Sep 2015 20:10 #63141 by andypugh
I see you are in Brazil, perhaps it would be easier to ask the question in your native language? We have other users in Brazil.
28 Sep 2015 20:53 #63143 by cabocozika
o que eu preciso e contar as voltas que meu spindle ou o eixo a faz
Eu não preciso posiciona-lo tão exatamente
pois o que eu vou fazer é somente uma maquina para enrolar transformadores
mas o eixo ou o spindle e com um motor de corrente alternada e um inversor
mas o inversor não aceita escala pwm somente frequência
Time to create page: 0.076 seconds
