Linux Mint
- BigJohnT
- Thank you received: 994
03 Nov 2015 07:30 #64652
by BigJohnT
Linux Mint was created by BigJohnT
Has anyone patched a kernel for Linux Mint? I'm ready to jump off that cliff if I can get some guidance.
JT
JT
- Online
- Thank you received: 7493
03 Nov 2015 07:48 - 03 Nov 2015 08:51 #64653
Replied by tommylight on topic Linux Mint
I have 2.8.0-pre1-1156 installed on linux mint 17.2 installed form a deb on master branch and SIM works fine, i have not tried to do the RT yet but i can give it a shot and let you know how it goes.
Had to edit, uname -v gives me 14.04.1 ubuntu !!!
Also did try the other debs i have of the 2.8.0 version and they do not work, only the sim uspace works.
Regards,
Tom
did some more testing and the only deb that works for sim is
linuxcnc-uspace_2.8.0~pre1.1196.ge2b0651_i386.deb found at buildbot, the precise version, not the wheezy version.
Regards,
Tom
Last edit: 03 Nov 2015 08:51 by tommylight. Reason: more info
- Thank you received: 1480
03 Nov 2015 10:22 #64657
Replied by Todd Zuercher on topic Linux Mint
You can install the desktop environments used in Mint onto a Linuxcnc Wheezy install. I put Mate onto a machine recently.
wiki.debian.org/Mate.
- Online
03 Nov 2015 10:30 #64658
Then again i did a wheezy install and then i removed everything that i don't need from it, and then made an image of it. I like to start light and build to what i need.
Much easier !!!You can install the desktop environments used in Mint onto a Linuxcnc Wheezy install. I put Mate onto a machine recently.
- BigJohnT
03 Nov 2015 19:08 #64690
by BigJohnT
I have Mate on both my Wheezy computers already. It seems to me that Debian is still an underlying PIA and was wanting to try something different.
JT
Replied by BigJohnT on topic Linux Mint
JT
Time to create page: 0.137 seconds
