Joint compensation on a 6 axis robot
10 years 11 months ago #66130 by robottom
Hi Andy,
I followed the steps and compiled the whole linuxcnc into linuxcnc-dev what seems to be successful. Then I tried the same as in the post:
forum.linuxcnc.org/forum/24-hal-componen...s-component?start=10
The steps with the
. ./scripts/rip-environment
and then the sudo comp --install genserkins.c
does not work. I'm getting the same warning during compile as before.
When I try to do the same as the user dimech did in the post the genserkins.ko is not working when I simply copy it over from linuxcnc-dev/src into the modules folder of the real system. There is the error
could not insert module ....genserkins.ko: Invalid parameters.
The same with the pumakins.ko is working fine (as for dimech).
I need to say that I'm running a linuxcnc on Debian 2.6 while the git branch is the origin/2.7 - master git branch what is not fitting 100%. I tried to enter a different branch in:
git branch --track v2.5_branch origin/v2.5_branch
git checkout v2.5_branch
something with 2.6 but this is not working - git can't find it:
fatal: Not a valid object name: 'origin/v2.6_branch'.
I did not find any info via google what are the available branches.
Do I need to install a new 2.7 system - do you think it will run this way?
I'm very sorry but I'm new to git and the whole compile setup.
Would be very kind if you can give me a hint again.
Many many thanks,
Thomas
10 years 11 months ago #66131 by andypugh
robottom wrote: and then the sudo comp --install genserkins.c
Yes, that is why you are compiling everything at the same time.
You ought to find that your modified genserkins is already installed in the rip-environment version of LinuxCNC, and there will be a genserkins.ko with a recent creation date somewhere in linuxcnc-dev.
If you want to create a kins with a different name (and this is likely to be a better idea than creating a different kins with the same name) then make of renamed copy of (for example) pumakins and then ads your new kins in all the places that pumakins appears in the Makefile:
For example line 277
github.com/jepler/linuxcnc-mirror/blob/master/src/Makefile#L277
and lines 917, 918, 919, 920 and 1037
The 917 area is where the required includes are linked, to allow compilation.
10 years 11 months ago #66134 by robottom
Hi Andy,
so far I understand and I want to work this way with a new copied version of genserkins under a new name with my modifications included. But first I want to check if the original version that I compiled inside linuxcnc-dev folder works as intended.
And here I'm struggling. The compilation worked and the genserkins.ko file was there in linuxcnc-dev/src as expected.
But when I exchange the genserkins.ko in the modules folder of the orginal system with this compiles version the AXIS is starting with the error above.
I think this is maybe because of the wrong source version (2.7) from github vs. my running system on 2.6.
Before I newly install my laptop with the 2.7 wheezy I want to cross check if the issue might be somewhere else and reinstalling will not help (with the work of reinstall and setting it up from scratch).
Not sure if you can easily assess if this is the issue. If you are just gessing it is also o.k. because I don't see anything else that might be wrong.
The alternative would be that there is a git branch that fits to my current system 2.6. This would be much easier to check.
Many thanks, Thomas
10 years 11 months ago #66136 by andypugh
robottom wrote: I think this is maybe because of the wrong source version (2.7) from github vs. my running system on 2.6.
There are three ways round this, in order of likelyhood to work without causing further problems.
1) do the . ./scripts/rip environment thing and start linuxcnc from the command line, that will start the 2.7 version that you just compiled.
2) Start again at the ./configure stage and ./configure --prefix=/usr That will install newly-compied 2.7 in place of your 2.6 (but, because it isn't packaged, it might be hard to uninstall).
3) in the git repository git checkout -b origin/2.6 then recompile and see if the 2.6 .ko then works.
10 years 11 months ago #66179 by robottom
Hi Andy,
thanks so much for your help. Indeed 3.) worked fine. I was first surprised after entering git checkout -b origin/2.6 that it took only a few seconds. I thought it has to sync the whole 2.6 branch but obviously only the changed files.
After that the compilation worked and the new .ko file was working fine with my 2.6 system.
I check now the modifications inside a new named file and see if it works.
So far many thanks,
Thomas
10 years 10 months ago #67176 by robottom
Hi Andy,
while the 3rd option worked somehow successful on one of my Debian systems A I was using the same procedure on another Debian 2.6 system B. But this was not successful. Maybe I did something a bit different. Since I don't completely understand the system and the steps I'm a bit lost.
When I copy my new .ko file (genserkinspuma.ko) from the running system A to the system B I also want to setup for compilation the .ko file works fine. When I run the makefile on the system B and copy over from the src folder into to the running system under usr/... this genserkinspuma.ko fails to start with the known errors. What is also one indication of different files is that the genserkinspuma.ko on the good system A is 298,5kb while the other system B it creates a 291,0kb file.
I'm struggling really to find out on what version the runtime system is and what is the checkout version of git is. Is there some information on what the version is?
When I do git checkout origin/2.6 - is there no need to specify the subversion like 2.6.12?
I'm a bit lost and would be nice if you could help me again. Since your hint is working on machine A I assume it should work also on the other machine B that was installed from the same Debian image as the other one (both I guess on 2.6.12)? I guess there is just one little step different.
Many thanks again,
Thomas
Time to create page: 0.319 seconds
