Tool compensation switching plane
10 years 7 months ago #71318 by REEEN
Hello Andy,
I like that idea.
But I would switching between motors from y and z cause also switching parameters ? Like acceleration and maxvel ?
I have an idea how to sole the following error problem.
To tilt the head the machine musst be in a safe position, this can be g0 g53 z0 y0. So now y and z are 0 in machine coordinates.
What I don't like is the fact that the user needs to remind that axes change after head tilt, this can sometimes be a bit complicated for them.
Greets Rene
10 years 7 months ago #71334 by REEEN
Andy,
I think switching the kinematics is a problem because of the axes drives, they will receive wrong parameters when switching between them.
What I still prefer is using a seperate virtual axes and a advanced kinematic to do the job, in your example you showed me how to do it with xyzb config.
To rotatet the tool towards the user I need to use an a axis instead of b.
Do you know, what exactly I need to change ?
Thank you !
10 years 7 months ago #71338 by andypugh
REEEN wrote: Andy,
Possibly not...
In the Joints_Axes branch of linuxCNC (which is intended to make special kinematics work better) the limits are joint-based.
wiki.linuxcnc.org/cgi-bin/wiki.pl?JointAxesBranch so things should still work OK as far as travel limits go.
Having said that, I would be tempted to try creating a virtual machine (Vismach isn't that hard to get to grips with) and trying out configs on that. This would also allow you to trial it with the customer to see if they like it.
Once you have the virtual config all set up it is relatively easy to hook it up to the real hardware.
linuxcnc.org/docs/2.7/html/gui/vismach.html
It may be that re-mapping the tool change to run G43 in vertical mode, but to use G43.1 in horizontal would work.
IF (Vertical)
G43 H #<toolnum>
ELSE
G43 H #<toolnum>
#1 = #5401
#2 = #5402
#3 = #5403
G43.1 X#1 Y#3 Z#2
ENDIF
In an ideal world a reference tool would be created for a height-setting gauge which located the tip _exactly_ at the point of rotation of the head.
Time to create page: 0.073 seconds
