scarakins j3 strange min limit error on JA
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Mar 2016 11:43 #72041 by bkt
Hello at all,
I work around my firs scara with standard scarakins .... I have strange problem:
1- when stop my ngc program at casual program row and reload for start to beginning axis show a popup error with these advice: C axes exceed minimun limit. To restart are obliged to return the Scara in home position and restart JA9. Redoing the home without restarting does not work.
2- During the normal work with my ngc program (in ngc not have command for A/j3 axis) the j3 move correct but if I reverse the trajectory of the J3 Scara moves a little before following properly the other axes for example my program move 25 time from x500 y400 to x500 y-400; when the motion revers I see the issue.
in attach my j3 ini file and j3 hal ..... I make some stupid error that I not show??
Warning: Spoiler!
29 Mar 2016 10:15 #72330 by andypugh
Replied by andypugh on topic scarakins j3 strange min limit error on JA
JA9 is a fair way behind now there is a JA12.
I don't know if that will help with the problem, it might be a problem in scarakins.
The following user(s) said Thank You: bkt
  • bkt
  • Platinum Member
  • Platinum Member
30 Mar 2016 05:35 #72375 by bkt
I try it....
Giorgio
Time to create page: 0.072 seconds
