Manual (keyboard) jog speed for milling
- FiliP
09 May 2016 09:56 - 09 May 2016 09:57 #74410
by FiliP
Manual (keyboard) jog speed for milling was created by FiliP
Hi.
Is there a way to set value for manual jog speed (Axis 2.7.4)?
Sometimes i want to mill by hand, but cant set exact value using jog speed slider
Cant find hal pin for slider value...
Last edit: 09 May 2016 09:57 by FiliP.
- Thank you received: 1483
09 May 2016 10:30 - 09 May 2016 10:45 #74413
Replied by Todd Zuercher on topic Manual (keyboard) jog speed for milling
You can set it with a Halui pin.
halui.jog-speed
Never mind that doesn't' seem to work for keyboard jogging in axis. (It only sets the jog rate when using the halui pins for the inputs.)
halui.jog-speed
Last edit: 09 May 2016 10:45 by Todd Zuercher.
- FiliP
09 May 2016 13:28 #74421
by FiliP
Replied by FiliP on topic Manual (keyboard) jog speed for milling
No, halui.jog-speed don't work - checked before post this question here.
Thx for trying.
Thx for trying.
- Thank you received: 4663
10 May 2016 10:56 #74452
It is probably easier (and better) to use MDI, that is what I typically do.
I quite often drill with the jogwheel, though, and you might prefer to fit one of those for hand operations.
Replied by andypugh on topic Manual (keyboard) jog speed for milling
Time to create page: 0.109 seconds
