M User Defined Command to use with a Gripper
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
16 May 2016 09:16 #74745 by jstoquica
I want control a electromechanical gripper for my robot, with a M User Defined Command.
I have a Breakout board for do that. I have 2 free outputs (pin 1 and 16) to active two relays, and each one can control a state of the gripper (OPEN and CLOSE) with two independent solenoids.
I only need a pulse for control the gripper states, for example:
- M101 to open
- M102 to close
How can I do that?
This is the correct way? But I need only a HI pulse (e.g. 25 ms), I can't leave active the solenoids, I need temporize the output state. Is this possible?
#!/bin/bash
# file to turn on parport pin 14 to open the collet closer
halcmd setp parport.0.pin-14-out True
exit 0
I normally can use two buttons with PyVCP, one for each gripper state, and I can control the timing while push and release the buttons. But I want use the gripper with a G program.
Thanks a lot.
16 May 2016 11:18 #74750 by Todd Zuercher
Replied by Todd Zuercher on topic M User Defined Command to use with a Gripper
That might sort of work. The command "halcmd setp parport.0.pin-14-out True" will turn on the parallel port pin 14, but it will stay on (true) until something changes it back to false.
There are probably several ways to make it only a momentary signal. One way would be to use the parport driver's reset feature (often used with software stepping to achieve one step/thread cycle). Another way would be to add a sleep to your M-code script like this.
M101
#!/bin/sh
sleep .030 ;# requires a sleep that does <.030
halcmd setp parport.0.pin-14-out False
exit 0
16 May 2016 11:23 - 16 May 2016 11:25 #74751 by PCW
I would use M64 and M65 to set the state of the gripper and wire the hal pin thats controlled by M64 and M65
( motion.digital-out-00 for example) to two one shot components (man oneshot) set for 25 ms time with
one one-shot programed to trigger on the rising edge of motion.digital-out-00 and the other programmed to
trigger on the falling edge of motion.digital-out-00
(you could also use a single oneshot and some steering logic but I think the dual one-shot approach is simpler)
I would not use a userland halcmd routine for a 25 ms pulse as its timing is not guaranteed
Last edit: 16 May 2016 11:25 by PCW.
16 May 2016 11:44 #74753 by Todd Zuercher
I know that the time isn't guaranteed, but it is going to be at least that long isn't it? And since I thought he only needed something analogous to pressing a momentary button, should be good enough.
16 May 2016 11:57 #74755 by PCW
Yes, it will stay on for at least the sleep time but the maximum on time is not knowable
I was just concerned that driving an intermittent duty cycle solenoid without
good control of the on time might not be a good idea
  • jstoquica
  • Premium Member
  • Premium Member
16 May 2016 16:04 #74778 by jstoquica
Replied by jstoquica on topic M User Defined Command to use with a Gripper
Hi Everyone,
Thanks a lot, I use a solution with sleep command and is working.
#!/bin/sh
# file to turn on parport pin 01 to open the gripper
halcmd setp parport.0.pin-01-out True
sleep .50
halcmd setp parport.0.pin-01-out False
exit 0
Regards.
Time to create page: 0.080 seconds
