PWM depending on Z axis value for engraving or Laser
21 Sep 2016 19:13 #80734
It would probably be possible. But you would need to find an openGL programmer who can do Python.
A GladeVCP tab to display the input image file is almost certainly much easier.
Replied by andypugh on topic PWM depending on Z axis value for engraving or Laser
What are the chances of superimposing a picture on the plot screen when i open a gcode file?
- Thank you received: 7478
21 Sep 2016 19:28 #80736
Replied by tommylight on topic PWM depending on Z axis value for engraving or Laser
Oh goody, that can work too, as i need that picture to change so will give it a try later, now need some food.
Andy, Thank you very much.
02 Mar 2026 22:53 - 02 Mar 2026 22:58 #343758
Latest config with provisions for disabling PWM on program pause or stop and enabling on resume.
Edit:
Attached the latest config to the first post, also.
Edit:
Last edit: 02 Mar 2026 22:58 by tommylight.
The following user(s) said Thank You: rdtsc
Time to create page: 0.635 seconds
