Going to the start position
- Feliciano
14 Oct 2016 02:03 #81632
by Feliciano
Going to the start position was created by Feliciano
I'm using a 7i80HD-25, with a 7i47s.
I have 4 minas S from panasonic, with have only the index pulse (because of the old retroffiting, they only use for homing) available. In my configuration everything works fine, except by the index.
When I run the home sequency with the USE_INDEX, the machine trips in to the home switch, finds the first index pulse (I've verified using hal meter) and then go to the, what I call, "startup position". The machine adds the distance between the home (where she found the home switch) and the place where the machine was localized on startup and then travels to the startup position and then she sets this as home.
My question is, this problem could been occuring because I'm not using the feedback from encoder on my hal?
There's any possibility of using only the index from my encoder just for homming and not having this problem? I have already build a machine with close loop, but was with encoder pulses, and the home worked fine, whenever I shutdown the machine, she never sets the initial point as home, like is happening now.
Sorry for my bad english, and thanks in advance.
- Thank you received: 5328
14 Oct 2016 03:06 #81633
Replied by PCW on topic Going to the start position
Index only works with encoder feedback, is this a step/dir system?
(there is FPGA hardware to support index on step/dir systems but it is not currently supported in the hm2 driver)
The following user(s) said Thank You: Feliciano
- Feliciano
14 Oct 2016 16:57 - 14 Oct 2016 16:57 #81649
by Feliciano
Replied by Feliciano on topic Going to the start position
Yes, I'm using a step/dir with this panasonic drivers.
I didn't tested the system with home, but I have already tested wit stepper motor drivers, and they seams to work fine with hm2.
Could be this the problem? If I complement my encoder signal (with A and B ) should work fine?
My other possibility is to use the classicladder to do some logic with this and assume only the home switch on hal but that's not what I want, seem a bit trick do this.
Last edit: 14 Oct 2016 16:57 by Feliciano.
14 Oct 2016 18:20 #81651
Homing to index currently only works if the systems position
feedback comes from an encoder
This means you need to setup the system with a stepgen in velocity mode
and use an encoder for position feedback
- steva
14 Oct 2016 20:47 #81653
by steva
Replied by steva on topic Going to the start position
Cheack in thread
forum.linuxcnc.org/forum/10-advanced-con...ch-index-pulse#39814
I use it and works very well.
- Feliciano
16 Oct 2016 13:28 #81688
by Feliciano
You are awesome guys.
I didn't have time yet to check this out, but I think I'll work.
Thanks a lot!!
Thanks a lot!!
Time to create page: 0.119 seconds
