How to build ATC Carousel in linuxcnc ?
10 years 6 days ago #82106 by mhdsi
andypugh wrote: Those are using G-code digital inputs ans ouputs:
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m62-m65
Those are connected to hardware by one of the HAL files in the config. If you ran the demo then you will now have all the files in your ~/linuxcnc/configs folder, but the HAL file for the changer looks like this:
github.com/LinuxCNC/linuxcnc/blob/master...toolchange_index.hal
If you are using a B-axis then you will have more G-code and less HAL to control things.
I see
Thank you very much !
I will try it
Thank you again !
10 years 6 days ago - 10 years 6 days ago #82108 by eneias_eringer
mhdsi wrote:
I've seen it many times before
It is my expectation :D
Can you share your configuration?
Yes !!! soon when arrive in my house , but some sub programs titles and comments are in portuguese !!! LOL
Last edit: 10 years 6 days ago by eneias_eringer.
10 years 6 days ago #82118 by eneias_eringer
Here is !!
Am sorry but my configs files are a little mess
File Name: BACKUPZX75...2016.zip
File Size:71.38 KB
The following user(s) said Thank You: mhdsi
10 years 6 days ago #82128 by mhdsi
eneias_eringer wrote: Here is !!
Thank Eneias Eringer very much!
Your configure make me understand port config (parport.0 is Parallel port, pin-xx is pinout of Parallel port) :D
Thank again !
6 years 9 months ago #154529 by rogerxue
I'm curious as how to use it without making it an axis?
I'm in the middle of adding a ATC to my machine, I use mesa5i25 + 7i76, the carousel using stepper with step+dir signals with a home switch.
thanks a lot
6 years 9 months ago #154538 by andypugh
rogerxue wrote: I'm curious as how to use it without making it an axis?
The "carousel" HAL component can align a carousel to a tool number (using various types of feedback) without the carousel being a G-code controlled axis.
Time to create page: 0.062 seconds
