andypugh wrote: The point is, it's G-code. You can set up any sequence you need.
mhdsi wrote: Can you give me an example of that ?
The file posted earlier was an example. Without knowing anything at all about your machine it's hard to think of any useful second example.
mhdsi wrote: what I need's how to configure port because i can't config output port for Arm in/out, sensor Arm in/out, Carousel index, Tool released/clamp, sensor tool released/clamp
Todd Zuercher wrote: So you are asking how to configure the actual io? That all depends what kind of physical interface you want to use. (parallel port, Mesa card...)
