Educate me about estop chains and latches
9 years 5 months ago #93567 by rodw
Bevins thanks, yes quite a difference given I only have about 90 pounds moving on the gantry.... It has always stopped dead in its tracks on estop. I think the idea when we set it up was to make sure there were no intermediate circuitry between disabling movement and pressing the button, just a mechanical switch. Switching 5 volts to the drive disable signal on the stepper controllers by the e-stop switch requires a working 5 volt power supply and using an output on the Mesa Card implies that the PC or the board has not hung.
The idea was always to learn how to make a machine so the next one will have a different estop switch that you can add as many switch mechanisms as you want to by clipping them to the back of the switch module.
9 years 5 months ago #93639 by tommylight
Heavy machinery must have braking resistors. Even some smaller ones have them, some inside the servo drives some outside. Some have terminals for them.
All motors have physical brakes on those machines, all of them without exceptions.
I have some 200W ones with brakes on them.
Time to create page: 0.049 seconds
