- Thank you received: 8
Do you have a working step-nc interpreter for LinuxCNC?jstoquica wrote: I have new delta kinematics function in Matlab, but I will use LinuxCNC because is an Manufacturing Application (step-nc additive manufacturing).
I am not sure what you are asking here. Is there any reason to believe that the Matlab-generated C-code will work better than the already-included delta kinematics modules? lineardetakins has a manual page here: linuxcnc.org/docs/ja/html/man/man9/lineardeltakins.9.htmlMatlab has tool code translation but I don't know if It can affect some delta kinematics variables.
Octave is a Matlab-compatible programming language which is open-source and free.What is Octave? .
I still do not have it, but there are several research groups working to development.Do you have a working step-nc interpreter for LinuxCNC?
I am testing with lineardeltakins file and our delta robot parameters. Does LinuxCNC version has a vismach simulation? We are doing a delta configuration one to test with LinuxCNC in offline and online mode.I am not sure what you are asking here. Is there any reason to believe that the Matlab-generated C-code will work better than the already-included delta kinematics modules? lineardetakins has a manual page here:
