M6T Remap
8 years 11 months ago #101852 by andypugh
Replied by andypugh on topic M6T Remap
pmcstoneinc wrote: o<change> sub
G53G0Z0
G4P0.1
G0 X40 Y-[#<_hal[iocontrol.0.tool-prep-pocket]>*150]
o<change> endsub [1]
m2
using stdglue.py remap for M6, TX is just looped together
If you are using stdglue, then you _should_ see the tool in #<selected_tool> ? No need to go looking at HAL pins.
(also see #<tool_in_spindle>, #<current_pocket>, #<selected_pocket. )
github.com/LinuxCNC/linuxcnc/blob/master...ython/stdglue.py#L52
The following user(s) said Thank You: pmcstoneinc
8 years 11 months ago #101859 by pmcstoneinc
Replied by pmcstoneinc on topic M6T Remap
DOH! Thanks again andy!!!
8 years 11 months ago #101904 by andypugh
I am wondering if your problem was that the remap line in the INI defined your new M6 to have a higher priority than the T command?
What modal group did you choose for the M6?
(Think)
Actually... HAL pin access from G-code can never work for this, the values read are the values active when the program starts...
See the not-very-forceful Note here: linuxcnc.org/docs/2.7/html/remap/remap.h...ap:referto-hal-items
8 years 11 months ago #101951 by pmcstoneinc
Yeah the modal groups are correct. I did not know the parameter was being pushed in the prolog, def had my blinders on for that one, lol. Thanks again for everything andy!
Time to create page: 0.053 seconds
