[SOLVED] MPG help
17 Jul 2010 15:39 #3393
by BigJohnT
Replied by BigJohnT on topic Re:MPG help
Looks fine to me... I think once you have some encoder counts coming in you will get it working in a hurry.
I'll wander out to the shop to see how I have my encoder hooked up on my Hardinge...
17 Jul 2010 15:54 #3394
by BigJohnT
If you have a 7i33 Quad Servo Card I would connect the MPG to that. On my Hardinge I have the following connections on my 7i33 for the MPG
Here is my Hardinge hal file.
+5V = 5 VOLT BUSS
ENCB3 = MPG B
GND = 0 VOLT BUSS
ENCA3 = MPG A
18 Jul 2010 05:53 - 22 Jul 2010 16:11 #3401
by Pentax
Replied by Pentax on topic Re:MPG help
thanks a lot John, I'll give it another shot when i get back on Tuesday.
Last edit: 22 Jul 2010 16:11 by Pentax.
21 Jul 2010 21:37 - 21 Jul 2010 21:52 #3448
by Pentax
Last edit: 21 Jul 2010 21:52 by Pentax.
22 Jul 2010 00:23 - 22 Jul 2010 00:27 #3449
Replied by cmorley on topic Re:MPG help
post your last HAL file.and we'll check out mux4.
How is your selector switch wired?
Chris M
Chris M
Last edit: 22 Jul 2010 00:27 by cmorley.
22 Jul 2010 13:15 #3453
by BigJohnT
mux4 is a two input 4 output selector switch. Depending on what inputs are "on" defines which output is "on". The outputs are configured by setting the pin value for each output. In your hal file setp is what sets a pin value.
www.linuxcnc.org/docview/html//man/man9/mux4.9.html
Kind of a computer geek description but it is all we have atm.
22 Jul 2010 15:58 - 22 Jul 2010 16:00 #3459
by Pentax
Ok, here is the latest hal (it could use a little cleaning, sorry).
There were a couple of tricks to getting the encoder to function. I had it leaching legacy power for a universal power supply inside the box that i use for relays and general power, it fluxuated from 4.5-5.2 VDC. I switched it to the mesa power supply which puts out a reliable 4.78 VDC. I don't know if the encoder circuit on the MPG is sensitive to fluctuating power, it shouldn't be, but i did that anyway.
I changed the .ini to have four encoders instead of three, which appeared to be key. I was using the 3 axis servo example provided with the emc build on dapper drake.
And lastly, I stared at the hal file until it worked.
The mux4 is the only thing that is misbehaving. I have two switches on the unit, one three way, and a four way. The three way is fully functional and has X, Y, and off. (there is no z on this machine). The other switch is .1, .01, .001, .0001. This switch behaves oddly. I have a ground going to the pole, and four GPIO pins going to the .1, .01, .001, and .0001. Mux4 seems to accept only two pins? you can see in my hal that i attempted to have it use all four, but it failed.
Thanks again for the help guys,
A
A
Last edit: 22 Jul 2010 16:00 by Pentax.
22 Jul 2010 23:22 - 22 Jul 2010 23:24 #3463
by BigJohnT
mux4 only has two inputs and four outputs.
so you have to wire your selector switch to produce the above inputs for the mux4 to work properly. So in position 1 you have no lines on... in position 2 you have one line one etc.
If you look again at my config you will see that I named my mux4 mpg-scale. So looking at my MPG section you can see where I set the desired values for the in's and where I connected inputs to my mux4 (named mpg-scale)
in0 in1 output
off off 0
on off 1
off on 2
on on 3
Last edit: 22 Jul 2010 23:24 by BigJohnT.
22 Jul 2010 23:43 #3466
To use your selector switch with a mux 4 you must multiplex the switch connections
Probably pretty easy using some diodes....or
If you use mux8 you could get three jog speeds with out multiplexing the switch connection.
I was gonna say mux16 (for four speeds) but that is only in the developer version yet....
03 Aug 2010 18:29 - 03 Aug 2010 18:32 #3566
by Pentax
Ok, its all good. Fully functional. i have .1, .01, .001, and .0001 . Here is a copy of my final and cleaned hal file. I ended up using a 3 pole 4 position switch to get what mux4 wanted (off-off, off-on, on-off, and on-on), which is probably overkill, but it was quick and cheap to setup.
yay.
Thanks for the help.
yay.
Last edit: 03 Aug 2010 18:32 by Pentax.
Time to create page: 0.490 seconds
