using HAL to correct axis errors
18 Feb 2018 02:47 #106115 by Mike_Eitel
Replied by Mike_Eitel on topic using HAL to correct axis errors
I like your true diy
18 Feb 2018 09:14 #106135 by pgf
Replied by pgf on topic using HAL to correct axis errors
I think "true diy" might be a euphemism for "doesn't work all that well". :-)
18 Feb 2018 09:24 #106136 by Mike_Eitel
But its fun to think about and tinker.
Have fun!
28 Feb 2018 11:22 #106725 by andypugh
Replied by andypugh on topic using HAL to correct axis errors
There is also a special kinematics file that can be used to correct a skewed machine:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...y_XY_skew_correction
That might not work so well with a gantry machine, it predates joints-axes.
28 Feb 2018 11:32 #106728 by pgf
thanks andy. guess that could have saved me a bit of work. oh well -- it wasn't hard, and i enjoyed it. and what's most important....
MY MILL CAN CUT RIGHT ANGLES!!!
there. just had to say that. :-)
paul
28 Feb 2018 13:03 #106739 by Mike_Eitel
Nice to read from a happy man!
The following user(s) said Thank You: pgf
04 Sep 2022 04:43 #251158 by LAUSCH
Replied by LAUSCH on topic using HAL to correct axis errors
Hi paul,
Can you explain why you set:
option singleton yes;
If you do this you will get errors from the lines in HAL:
addf nonsquare-table.0.cmd servo-thread
addf nonsquare-table.0.fb servo-thread
I have thus comment the line
//option singleton yes;
And LinuxCNC starts without error.
Cheers
Christian
04 Sep 2022 13:00 #251178 by pgf
Well, I clearly didn't get errors from that code when I last ran the mill. I had to look up what the "singleton" option does -- it seems appropriate for this module, since you can really only have one of these components per system. But perhaps you're running a newer version of hal, with tighter restrictions on naming.
paul
05 Apr 2025 09:57 #325765 by pgf
I wanted to bring this thread up to date, in case anyone finds it and finds it useful.  I recently upgraded my mill from 2.7.4 to 2.9.4, which of course brought in the joints axes changes.
Those required some rework of my skew corrector.  The component module itself was unchanged.  It's in a post above .
But the linkage into HAL did change, due to joints axes, and the introduction of pid.
First, 2.7:      the original HAL had a fairly simple connection between motor and stepgen:
  ypos-cmd
      axis.1.motor-pos-cmd ==> stepgen.1.position-cmd
  ypos-fb
      stepgen.1.position-fb ==> axis.1.motor-pos-fb
  xpos-cmd
      axis.0.motor-pos-cmd ==> stepgen.0.position-cmd
  xpos-fb
      stepgen.0.position-fb ==> axis.0.motor-pos-fb
I was able to simply insert the nonsquare function block into the middle of each Y axis signal path, and tap into the X signal path.
 ypos-cmd
      axis.1.motor-pos-cmd ==> nonsquare-table.y-in
  ypos-cmd-adjusted
      nonsquare-table.y-out ==> stepgen.1.position-cmd
  ypos-fb-adjusted
      stepgen.1.position-fb ==> nonsquare-table.y-fb-in
  ypos-fb
      nonsquare-table.y-fb-out ==> axis.1.motor-pos-fb
  xpos-cmd
                           ==> nonsquare-table.x-in
  xpos-fb
                            ==> nonsquare-table.x-fb-in
The newer LinuxCNC path in 2.8/2.9 is a little more complicated, with the introduction of the PID mechanism.
  y-pos-cmd
      joint.1.motor-pos-cmd ==> pid.y.command
  y-output
      pid.y.output ==> hm2_7i96.0.stepgen.01.velocity-cmd
  y-pos-fb
      hm2_7i96.0.stepgen.01.position-fb ==> joint.1.motor-pos-fb
                                        ==> pid.y.feedback
  x-pos-cmd
      joint.0.motor-pos-cmd ==> pid.x.command
  x-output
      pid.x.output ==> hm2_7i96.0.stepgen.00.velocity-cmd
  x-pos-fb
      hm2_7i96.0.stepgen.00.position-fb ==> joint.0.motor-pos-fb
                                        ==> pid.x.feedback
Integrating the nonsquare function in the new HAL is similar, butasymmetric.  TreIn the output direction, the nonsquare function is inserted between the joint and pid (which then feeds stepgen), but in the feedback direction, we insert between stepgen and the joint.
Regardless, the new function is inserted just after (cmd) and before (fb) the joint command.  The X control for the new function is similarly attached directly to the joint function.
  y-pos-cmd
      joint.1.motor-pos-cmd ==> nonsquare-table.y-in
  new-y-pos-cmd
      nonsquare-table.y-out ==> pid.y.command
  y-output
  y-pos-fb
      hm2_7i96.0.stepgen.01.position-fb ==> nonsquare-table.y-fb-in
                                        ==> pid.y.feedback
  new-y-pos-cmd-fb
      nonsquare-table.y-fb-out ==> joint.1.motor-pos-fb
  x-pos-cmd
  x-output
  x-pos-fb
                                        ==> pid.x.feedback
Time to create page: 0.744 seconds
