adjust z while milling
- billykid
- Thank you received: 83
01 May 2018 13:17 #109926
by billykid
adjust z while milling was created by billykid
hi, as it is not very easy to adjust the height z to mill a printed circuit I would like to be able to adjust + or - 0.1 mm while working, in steps of 0.01 mm maybe with a manual encoder.
the system is closed loop with servo dc, just an idea to understand if you can.
thank you
Mauro
thank you
Mauro
- skunkworks
- Thank you received: 153
01 May 2018 13:41 #109928
by skunkworks
Replied by skunkworks on topic adjust z while milling
Look at the offset component. You hook it between motion and your pid (or however you have your system setup)
linuxcnc.org/docs/html/man/man9/offset.9.html
then you can send it offset amounts that motion doesn't know about. You probably want to put a limit3 before it.
sam
sam
The following user(s) said Thank You: billykid
- billykid
01 May 2018 13:47 #109930
by billykid
Replied by billykid on topic adjust z while milling
thank you ! it seems just what I need
- billykid
01 May 2018 16:21 #109945
by billykid
I looked to see some examples but all refer to moveoff ..
this is the Z section of my hal, I wrote next to the signals to intercept in my opinion.
can you take a look?
thank you
Mauro
thank you
Mauro
- Thank you received: 4658
02 May 2018 18:41 #110072
Replied by andypugh on topic adjust z while milling
Probekins was written for this. I don't know if ir ever properly worked.
wiki.linuxcnc.org/cgi-bin/wiki.pl?ProbeKins
Something like that and the External Offsets branch would work.
- billykid
03 May 2018 02:29 #110099
by billykid
thanks Sam and Andy, I did with offset, very simple to use just as I meant
with a 24 cpr mechanical bourns encoder I can change z 0.001 mm in pitch.
if someone interested in the file there are the changes I made.
Mauro
Mauro
- alan_3301
- Thank you received: 22
26 Oct 2018 11:54 #119463
by alan_3301
Just for the record, I use probekins on my router sometimes, and it works great as long as you know and follow the limitations.
forum.linuxcnc.org/10-advanced-configura...sing-probe2stl#30130
Replied by alan_3301 on topic adjust z while milling
Time to create page: 0.195 seconds
