Editing theta offset with genserkins?
  • Wireline
  • Wireline's Avatar Topic Author
  • Senior Member
  • Senior Member
03 May 2018 15:12 #110142 by Wireline
Editing theta offset with genserkins? was created by Wireline
Hi
I thought I would make a new (much shorter) post on genserkins and DH parameters rather than add to the old one!
Is there a way to add theta (as opposed to just the alpha, d and a parameters) offsets in genserkins? I have tracked my problem down to needing a 90 degree offset at my first joint in order to make the home locations correct.
Cheers
09 May 2018 07:23 #110430 by andypugh
Replied by andypugh on topic Editing theta offset with genserkins?
Does setting the home position to 90 have the same effect?
  • Wireline
  • Senior Member
  • Senior Member
09 May 2018 14:11 #110444 by Wireline
Replied by Wireline on topic Editing theta offset with genserkins?
Hi Andy
In the end I went for a different home position as the kinematics seemed to cope much better with it. I am not sure of the mechanics of how genserkins treats the home position offsets. That said I did come across a different version of genserkins called DHKINS which allowed for inputting theta. I never got around to using it due to the above alternative plan.
11 May 2018 21:03 #110591 by thang
Replied by thang on topic Editing theta offset with genserkins?
i guess you mention about rotating coordinate system,in this case i think you should write some new functions in genserkins.
18 Jun 2020 15:32 - 18 Jun 2020 15:33 #172037 by Tady
Replied by Tady on topic Editing theta offset with genserkins?
Hello
I also need J1 THETA offset. How did you implement the dhkins.c?
I downloaded the C and H files from here
alvarestech.com/temp/RoboAseaIRB6S2-Fiat...C/halitosis/dhkins.c
I used
halcompile --install dhkins.c
But what did you use in the ini file. I replaced the genserkins with dhkins but LinuxCNC does not load..
insmod for dhkins failed, returned -1
The genserkins is working perfectly in the simulation, but the pose of the robot is not practical. I would like the J1 to be upright (-90degrees). The home offset does not work
Thank you
Last edit: 18 Jun 2020 15:33 by Tady.
Time to create page: 0.279 seconds
