Using ilowpass with software encoder mesa 7i76
- Clive S
- Thank you received: 486
11 Jun 2018 05:33 #112180
by Clive S
Using ilowpass with software encoder mesa 7i76 was created by Clive S
With a lot of help from the forum I successfully managed to use ilowpasss to smooth out the mpg clicks using a mesa 7i85s file attached.
I am trying to do the same using a mesa 7i76 software encoder.
The problem I have is that altering the gain just delays the output from the mpg but does not smooth it like it does with the 7i85s
I have attached my custom_ilowpass_mpg.hal this is for 7i76 . I am trying just to get the X axis working first
Is it indeed possible using the software encoders?
- Thank you received: 5337
11 Jun 2018 08:27 #112189
Replied by PCW on topic Using ilowpass with software encoder mesa 7i76
Ilowpass needs a large scale factor to work
(and the jog increments needs to be divided by this scale number)
linuxcnc.org/docs/html/examples/mpg.html
(look at the ilowpass scale and gain numbers in the example)
- Clive S
11 Jun 2018 11:32 #112195
by Clive S
Yes of course I had forgot. I adjusted scale and gain and its all fine. Thanks for the help yet again:)
Replied by Clive S on topic Using ilowpass with software encoder mesa 7i76
Time to create page: 0.476 seconds
